Looking to buy oil accumulator. What do I need?
Received 1,741 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I am looking to get an accumulator for my 1990 C4. What is a good brand but not too pricey? I dont need anything special like pre-oiling, just one to save my engine at the track. What are all the parts/fittings required? Where do I mount one? I plan on running an external cooler as well.
I mounted the Accusump inside the car in my '94 Camaro tracker and if your car is track only this will be the easiest method.
You get the benefit of pre-oiling with no extra effort BTW.
Here are some links for C4/C5. Hope it helps.
I would do an search for "C4 accusump" and see what comes up.
http://forums.corvetteforum.com/auto...ump-on-c4.html
http://forums.corvetteforum.com/auto...-accusump.html
Good luck.
Good luck.
Do a quick search. There was a thread by the same name last fall that had pics and a complete part list. I have it saved at work. Plus a neat idea of powering to fuel pump fuse so it wouldn't unload everytime you turned ignition on. Good luck.
Here's a good set-up for a little over $1,000 at Livermore Performance.
http://www.livermoreperformance.com/...engine.html#LP
I just got a Moroso 3Qt accumulator and a simple oil cooler. Will he be able to tell me how and where to run it?
