New Plastic molded Complete C6 C6Z Brake ducts
Old 03-02-2009, 02:28 PM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default New Plastic molded Complete C6 C6Z Brake ducts
Hi guys,
NO more modifying! now available custom molded full 3" ducts.
As some of you know, we have been modifying plastic ducts for the C6 and C6Z for some time now. We finally had the tooling completed and the new molded ducts are ready.
These are made for the full 3" hose and will mate right up to any 3" spindle duct. ANd we had 3" aluminum tube molded in to add strength at the hose connection.
Also, as you know, our 3" spindle ducts are a complete backing plate arrangement that keeps the air flow inside the rotor and out the cooling vanes.
We use only the best double lined silicone hose that won't break down. It is the ONLY hose that we use on our race cars.
Pricing for the plastic ducts shown is $199 per pair.
And our spindle ducts are a full 360 degrees to keep the air where it is supposed to be. the better the seal, the better the brake cooling.
Give us a call and we can answer any of your questions.
Lou Gigliotti
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Old 03-09-2009, 01:35 PM
LG Motorsports
And they are ready to ship. :thmubs:
Lou G
Old 06-09-2009, 06:51 PM
bobmoore2
bobmoore2's Avatar
The DRM ducts will not work with the Pfadt sway bars. Will your's?
Old 06-09-2009, 09:22 PM
JVetthead
JVetthead's Avatar
I have modded C6 ducts on my C5... With your spindle ducts.. Will these fit the same on the C5?
No Pfadt bar
Old 06-09-2009, 09:41 PM
LG Motorsports
Good question.
BUt if you already are using a C6 duct, then these will work.
They were designed and built using the Z06 ducts as the base, so they should fit. (but we have never done this.
LG
To New Plastic molded Complete C6 C6Z Brake ducts
Quick Reply: New Plastic molded Complete C6 C6Z Brake ducts
