Help with install of GM end links
Old 03-06-2009, 01:56 PM
Lan.Jet
Lan.Jet's Avatar
Default Help with install of GM end links
What is the proper orientation for the GM end links?
Example large end up or down
Bolt-bar- large spacer-link -small spacer-nut
Old 03-06-2009, 04:32 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
up down shouldn't matter.......the spacers go on each side of the "heim" so that it can rotate freely......you want to install them so that the link is as perpendicular to the mounts as possible. It really won't make much difference either way.
someone may have a specific answer for you, but there should be a fairly obvious "better" orientation once they are in place.
Old 03-06-2009, 05:19 PM
Lan.Jet
Lan.Jet's Avatar
Thanks for the reply also for the torque specs on your web site
To Help with install of GM end links
Quick Reply: Help with install of GM end links
