Anyone have experience with trailer "Ramp Overs"
I have done a lot of research and most enclosed trailers measure in at 81" between the wheelwells. A few are 83" such as the Haulmarks, but most are only 81". My track car is 79" wide without the wheels/tires and to load it into a trailer would necessitate changing the front two wheels/tires to a narrow set-up just to get the vehicle into the trailer. Even then I would only have 1" to spare on each side of the body possibly requiring multiple adjustments....
I am considering having "Ramp Overs" installed into my trailer. These are diamond plate aluminum ramps that are around 20" wide that run from the aft ramp and go up and over the wheel wells. I already have to winch the track car into the trailer to keep from burning up the clutch, so winching is already a requirement.
Does anyone have any experience with using these good/bad???
I can forsee that placing the tie down straps onto the frame would be much easier once the vehicle is 10" or so off the deck, but any negative issues to be concerned with?
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
I would think raising the center of gravity that much might cause some issues under braking.....but of course lots of trailer have lifts/lift gates in them, so it's probably not a big deal. I've never had any problems driving my cars right into all of the closed trailers I've had (Pace, Featherlite, etc), so it seems like a lot of trouble to me personally.
Is this a Vette, or something else???
those ramps actually look really nice, if you've got the $$$ to spare. Even would be nice for taking a look under the car in a pinch.
Still seems unnecessary to me, but it does look sharp.
Received 8,930 Likes
Some of the guys who run modifieds in my area have ramp setups similar to that in their trailer. However, their ramps are a little higher so they can push the car in and actually work under it if they need to during a race.
Bill
Bill
Yeah, the car is a widebody NASCAR type GTA car; 79" at the fenders and 82" with the race wheels/tires.
I spoke with Haulmark and they can build me a trailer with 83" between the wheel-wells but still only 83" wide. That would leave 0.5" on each side...
