Tire wear Patterns?
Tire wear Patterns?
What could be causing this kind of wear? The second to the outside tread is wearing more than the rest is this a Camber problem? Too much or to little
Are you tracking and if you are possibly too much pressure. I had to little and the sidewall took the hit. So besed on that I thinking too > pressure. I'm no expert
Yes, this car is tracked I only drive it on the street to get to the track.
I have been running 30 PSI hot and -.8 Camber. I was running the stock 2000 Z51 stabilizer bar. I have just installed a T1 bar. I don’t know if this will help or hurt this problem.
Thanks for the replies
Tire wear issue.
Forget about a negative camber problem. Too much negative camber will wear the inner tread first. Here, the outer tread is wearing. Too high tire pressure will wear the center tread first. Too much toe-in can wear the outer tread first, but will give a " finned " appearance to the tread, outside to inside, and more obvious on the right side tire. This does not look like a toe-in issue.
I'm thinking maybe you have low tire pressure and the tire tread is "rolling over " to the outside. What do the rest of you think?
I hope this helps.
Roger T
I hope this helps.
Roger T
I agree with LAST C5 - you need more negative camber - as much as the alignment tech can give you - and to raise your cold pressures a pound or two. This will even out the wear during track situations. On the other side of the coin if you also use the car for street driving, the extra negative camber will start to eat the inside of the tire in the same fashion. It's a damned if you do and a damned if you don't situation. Not enough negative = eat outside of tire on track. Enough negative for proper high loading track usage = eat the inside ribs of tire in street driving. If you go to R compound Kumhos or Hoosiers you will quickly destroy a very expensive set of tires without enough negative camber.
I was thinking I had to go more -Camber. The only problem is this is a C5 with C6 z06 rims and tolerance is very close. I heard the Z06 has longer trailing arms to get more clearance. I just installed 1/4 inch spacers. So maybe I can get a little more with out buying new rims.
Thanks for all the replies
No, it isn't the toe. The wear pattern would be indicative of excessive toe in. Excessive toe in wears the outside of the tire. If you have near zero toe the wear pattern is camber related. In this case more rear negative camber is called for.
I have been running 30PSI for about three years and only last fall after running about six days at lime rock did this problem start showing. I will be taking tire temps this year so that should help. I would think that because these are EMT tires if the pressure was low it would wear the edge more because of the hard block supporting the edges?
I am probably wrong I will try experimenting more this season it’s the only way to learn.
Thanks again for the help
Cartoon Character
I would also put a spirit level against the face of the tire to be sure that I did indeed have negative camber. It looks a lot like the tires on the front of my Suburban from hard cornering with zero to positive camber...
You said, "I have been running 30PSI for about three years and only last fall after running about six days at lime rock did this problem start showing."
Eureka! This is the clue we've been looking for!
I think your camber setting has moved/changed.
This is a common problem with Corvettes. If the eccentric bolt (used to set the camber) is not tightened enough, the eccentric can move, which will result in a more positive camber setting than you used to have. This is more likely to happen when you track your car, because the high cornering forces put a lot of pressure on the camber eccentrics. Occasionally hitting the apex curbing can also cause this.
Your tire wear indicates hard cornering with less than adequate negative camber. I believe that your camber adjustment moved last fall, so now you do not have 0.8 degrees negative anymore.
If I were you, I would have an alignment shop check all the alignment settings again, INSIST they torque the bolts correctly, then check the torque settings myself.
What do the rest of you think? Am I on the right track?
Bob
Bob
