Aluminum Lug Nuts
Old 03-11-2009, 01:53 PM
Last C5
Last C5's Avatar
Default Aluminum Lug Nuts
I see forged aluminum lug nuts guaranteed to about 300# torque for sale by various speed equipment dealers. Do they stay tight? Will they work for HPDE use? General thoughts, pro or con?
Old 03-11-2009, 03:38 PM
AU N EGL
AU N EGL's Avatar
April 1 coming early this year?
just go to NAPA and buy some open ended hardened lug nuts. $1.25 each never have to worry or think about it again.
besides if the Al ones get cross threaded
Old 03-11-2009, 04:19 PM
Aardwolf
Aardwolf's Avatar
I wonder at their service life, with vibration/use will the threads break down over time?
Old 03-11-2009, 04:56 PM
gkmccready
gkmccready's Avatar
First place I saw these last year:
http://www.flyinmiata.com/index.php?...umber=16-10000
Old 03-11-2009, 05:46 PM
flink
flink's Avatar
Old 03-11-2009, 06:15 PM
spazegun2213
spazegun2213's Avatar
I bought 20 new open ended steel nuts for $33 a few weeks ago at autozone now that being said, I've run Alu nuts on other cars and been just fine, but you go need to watch that they are not x-threaded.
Old 03-11-2009, 07:01 PM
Last C5
Last C5's Avatar
I figured they might cross thread easier, but it's easier to grab a new lug nut than change a stud so I was willing to live with that. My main concerns are if they're strong enough and will they stay tight. Sounds like they will. With all the heat generated on the track is there any problem with the variation of expansion and contraction between the steel studs and the aluminum bolts causing them to come loose? Also, how well do they survive the impact gun?
Old 03-11-2009, 07:03 PM
Last C5
Last C5's Avatar
Originally Posted by flink
I think this video was caused by a loose nut in the pits.
Old 03-11-2009, 07:52 PM
Davinss
Davinss's Avatar
Aluminum lugs do strip easily!
Old 03-11-2009, 08:07 PM
spazegun2213
haha, alu ones will show wear REALLY quickly (ie when used with an impact gun), and on a race car they simply will not last as long because of it. Mine never came loose, on my sti that was pretty damn fast. Although i was not racing in this car.
my advice is, get open ended steel ones
Old 03-11-2009, 10:06 PM
Last C5
Last C5's Avatar
Yea, probably the way to go. Thanks.
Old 03-12-2009, 07:55 AM
Locke
Locke's Avatar
I've been watching the aluminum ones for a few years with interest. It's not that I'm trying to reduce unsprung weight on a Stock class C4autocross car running Grand Sport wheels, I wanted the longer reach of a lug that is two to three inches long to lower the risk of hitting the wheel with the socket! I'm not really a concourser, really!
The import crowd is the largest user of the aluminum lugs and don't seem to have a problem with them. I asked one of the engineers with Enki who told me they were OK to run but needed to be watch very closely. I took that to mean they would need to be replaced with any signs of deformation in the seat area or threads. That worried me.....
I'm still looking for a set of steel, open ended, lugs that are 3" long but have only found ones that are over $100 for a set so far.
Personally, I'd stay away from the aluminun nuts unless you feel you just have to have the lowest unsprung weight in the paddock. First though, you'd better be spending thousands of dollars on the lightest wheel. Fiske, maybe????then worry about how much weight you're saving on the lug nuts.
P.S.
If you want them for the pretty colors, my advise would be to not tell this forum..........it might get ugly....
Old 03-12-2009, 12:56 PM
Last C5
Last C5's Avatar
P.S.
Sounds like they might be a problem, just when you don't need any problems. Guess I'll go back to steel.
No, I don't care what color they are, although I was attracted to some shiny purple ones I saw.
Well, now it's out to the shop to change out the wheel stud that started me thinking about using aluminum lug bolts.
Old 03-12-2009, 01:03 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Reminds me of the Ti lugnut thread
Old 03-12-2009, 01:09 PM
Aardwolf
Aardwolf's Avatar
Aren't the caliper brackets aluminum and held on with a similar torque? I can't remember. How about intake bolts, aluminum block bolts?
Old 03-12-2009, 01:17 PM
wallyman424
wallyman424's Avatar
yes yes, but those bolts aren't routinely taken off and put back on. think about how many times a racer/hpde'r removes wheels. i wouldnt trust an aluminum lugnut to last that many torquing cycles.
Old 03-12-2009, 02:01 PM
Aardwolf
Aardwolf's Avatar
Changing pads would be just as much but that bolt isn't torqued to the same ft/lbs as a lug. Anyways, just trying to put an aluminum fastener into perspective.
To Aluminum Lug Nuts
Old 03-12-2009, 06:32 PM
USA1C5
Support Corvetteforum!
USA1C5's Avatar
How about Titanium lug nuts. Strong and light. They pricey though. Anyone got any input on these.
Old 03-12-2009, 06:41 PM
wallyman424
300-500 dollars for a set of lugnuts? you've GOT to be kidding me.
the steel ones arent THAT heavy.
http://store.bimmerworld.com/shared/...t=products.asp
those are the ones I use. smaller than stockers, cheap and they've done just fine for 2 years now.
Old 03-12-2009, 06:48 PM
USA1C5
USA1C5's Avatar
I said they were pricey.
Quick Reply: Aluminum Lug Nuts
