Can Dunlop Slicks be Flipped?
Old 03-11-2009, 11:45 PM
Sidney004
Sidney004's Avatar
Default Can Dunlop Slicks be Flipped?
To extend life or are they asymmetrical. They are wearing on the extreme outer edge of the fronts. Running -3 deg., 30-32 psi hot. Fantastic tire, superior to R6 or V710 scrubs(that were treated with Formula V compound.)
Old 03-12-2009, 07:52 AM
AU N EGL
AU N EGL's Avatar
I would look at your alignment. -3 is good, but your still wearing out the outside edges ?
what is the rear set too?
Old 03-12-2009, 10:01 AM
Sidney004
Sidney004's Avatar
Extreme outer edge
No
I have got to check and see if it is not rubbing on the fender.
Checked, wasn't that.
Old 03-12-2009, 10:02 AM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Yes they can be flipped. But what AU N EGL said is also true. seems odd with that much neg camber that the outside would be wearing. Possibly a toe issue.
LG
Old 03-12-2009, 10:59 AM
Sidney004
Sidney004's Avatar
LG
Thanks Lou, perhaps I will doublecheck the camber and toe.
Old 03-12-2009, 04:01 PM
Armycop
Armycop's Avatar
I've got the same issue with mine, with -1.2 camber and .5 toe out from stock. I run mine at 36 cold tho. Could that be an issue?
Old 03-12-2009, 06:54 PM
LG Motorsports
36 psi cold is for sure an issue. We shoot for 32psi hot on the dunlop tires.
and a Half inch of toe out is also out of any range that we run. Max out=1/4 but normally out 3/16"
Old 03-12-2009, 07:48 PM
Armycop
Armycop's Avatar
Thanks Lou, I'll be making those changes before my next HPDE. Guess a visit to my alignment shop is in order...
To Can Dunlop Slicks be Flipped?
Quick Reply: Can Dunlop Slicks be Flipped?
