Tire Pressure
Old 03-18-2009, 11:21 PM
Operations
Support Corvetteforum!
Operations's Avatar
Default Tire Pressure
I am going to a track day at Texas World Speedway with The Drivers Edge folks and was wondering what tire pressure I sould start with in my C6 Z06 with stock run flats
Thanks in advance
Old 03-18-2009, 11:25 PM
tmak26b
tmak26b's Avatar
Thanks in advance
I used 31psi F&R when I did my TT on the run flats in my C6 Z51. I don't know if the Z06 is any better, but 2-3 laps is the most I can get out of the tires before they overheat and I slow down.
Old 03-18-2009, 11:42 PM
Corvee
Corvee's Avatar
Thanks in advance
When is the track day?
Old 03-19-2009, 12:51 PM
Operations
Operations's Avatar
This Saturday 21st
Old 03-19-2009, 01:09 PM
waddisme
waddisme's Avatar
Not sure if runflats are any different than regular, but I was under the impression you needed to be at 38-39 lbs when heated, so whatever it takes to start out to get to that. I would like to hear more input on this.
Old 03-19-2009, 06:17 PM
Lan.Jet
Lan.Jet's Avatar
I usually start at 26PSI cold they should be around 30 hot.
To Tire Pressure
Quick Reply: Tire Pressure
