Tire Width Question
Tire Width Question
I'm currently running 255/45R17's on 8" rims all around. Would putting 275's on the rear on 9.5" or 10" rims on the rear make a noticeable difference traction-wise for auto-crossing or HDPE, everything else being equal? Check out my signature at the bottom for the car's specs.
Thanks,
Bob
Thanks,
Bob
Changing the tire size does not increase the size of the contact patch. The size of the contact patch is determined by the weight of your car and the air presssure of the tire. Changine tire size will change the shape of the contact patch but not the size.
Richard Newton
Corvette Race Car Blog
Richard Newton
Richard's (rfn026) reply is completely correct, but it doesn't really address your question. Putting wider tires on your car will result in a better shaped contact patch, especially with side loads, which will result in better grip in curves.
The answer is "Yes".
Keep in mind that if they weigh a bunch more it will soak some HP which could result in no gain for lap times. So keep an eye on the weight! The stickiness of the compound plays a large role, perhaps just use stickier tires?
Bob
