<<<<Manual Transmission up front w/ DRM EOC in place????, TRACK CREW STEP IN
Cruise-In VII Veteran
<<<<Manual Transmission cooler up front w/ DRM EOC in place????, TRACK CREW STEP IN
1. C5Z06
2. DRM EOC w/ Ron Davis rad. RHS mounted -10 lines for the EOC
3. RPM M12 outback, I can run the lines up the rocker panel and get them to the alternator and/or rack area, can't find a GOOD path to the LHS 'in tank' trans cooler(the EOC lines are taking up a nice path near the motor mount)
4. Anyone have this setup??
5. DRM trans cooler in the side duct would be the 3 hour fix(OMITTING THE PUMP as it is already on the RPM trans), my friend chooses not to omit the rear brake ducts for the DRM cooler setup
Any help welcome, running typical braided -6 lines
