Nascar drilled rotors
At the Martinsville race this Sunday they were showing the latest, greatest hot set up for brakes since that track is very brake intensive and the rotor they showed was drilled. Thought that drilled rotors were a no, no for racing...or is it because they probably throw away the rotor after the race. One of the broadcasters (Waltrip?) commented on the problem with NASCAR brakes is the limitation put on them by the tire/wheel size. They didn't quite explain the calipers except to say they were much lighter than the previous ones. The clouds of brake dust during tire changes were awesome, cough, cough
The rotor & caliper that Jeff Hammond (the commentator) showed on TV is the new Raybestos-branded brake setup that Joe Gibbs Racing is working with. That rotor has a LOT more swept area then a normal Sprint Cup rotor, because the caliper has been re-shaped to be very narrow (and much lighter, too), to allow for the bigger rotor and still fit the whole deal within the confines of the mandated 15-inch diameter wheels.
It may have looked like the rotor was cross-drilled, but actually those indentations do not go all the way through the rotor, and are cast into it during manufacture, instead of being drilled through afterwards. It's hard to see that on TV, though.
Here is the caliper, claimed to be stiffest and lightest in NASCAR:
http://www.raybestoschassis.com/wps/...df?MOD=AJPERES
It is made by Alcon.
Here is the story:
http://www.raybestoschassis.com/wps/...Braking+System
13.15" O.D. x1.65" thk rotors, Raybestos pads:
http://www.raybestoschassis.com/wps/...ate+At+Bristol
Technical specifications:
http://www.alconusa.com/client_image...nt.13_97_4.pdf
Here is the story:
NASCAR just started to use aerodynamic aids. which was about mid 60s when the rest of the racing world starting using aerodynamics.
So if NASCAR is now just using drilled and slotted rotors, that is about right on the evolutionary level of nascar.
I watch F1 for high tech racing that is occasionally close racing (maybe the rule changes this year will improve that).
I watch NASCAR for close hard GREAT racing, even while their technology is controlled and dated in many areas of the car.
My personal opinion is that NASCAR only changes technology when they think they have a problem - typically when the racing starts to become less "close", and certainly for safety reasons - but they never implement new techno just for the sake of it.
Now fire away boys!
Oh, almost forgot - the original post was about brakes! Indeed NASCAR has some of the best brakes money can buy b/c the cars are so heavy. True, no carbon discs, and limitations due to the wheels, and some great engineering to fit great systems within those constraints (the very definition of engineering) but the abuse on the brakes at a track like Martinsville is incredible. Some of the teams use AP brakes at Martinsville as well.
there's only so much brake you can stick in a 15" wheel. The fact that they can work around that with a 900 hp 3400 lb car and have brakes at the end of the day at Watkins Glen/Martinsville/Infinieon is pretty amazing.
I shot some video for a piece we were doing a few yrs ago at Gibbs (before COT), they were prepping for m-ville that week. Here's a shot of what they were using back when. Hard to get a feel for the pads as the angle of the shot is steep, but those are the thickest pads I had ever seen
Tom was just being a hard-***, and I totally agree with him. I can't stand Nascar, but I do occasionally watch a lap or two now that they have aero treatment that compliment the current state of racing knowledge (sort of).
They discussed NASCAR braking a bit during the F1 race this weekend......Nascar brakes hit around 1000deg F, while F1 carbon brakes hit twice that much!!
Thank you very much.
What ever. YES Nascar does give lots of other motor sports support in one way or another. NASCAR does employee many many ppl, Heck almost whole towns north of Concord NC work for one team or an other.
and the amount or brakes, rotors, calipers and pads, these teams go though in a season. you an find almost any brake calipers you want on eBay from some NASCAR shop or anther.
NASCAR engineers are as sophisticated as any on the planet. They just must work within rules that are designed for even, close competition and cost savings rather than technology for technology's sake. As any of you following F1 know, the FIA and the related groups are looking at all kinds of cost savings, including annual budget caps, to bring costs back in line with reality. They are heading NASCAR's way, not the other way around. F1 may even have customer chassis before long....
And, if we really were to go to where tech is now, the driver would do very little and digital electronics, robotics and sensors would take over. We can already build cars that would generate g-loadings beyond what any person could readily handle if the rules permitted using more than 4wheels....and we could build a robotic car that could out-lap Lewis Hamilton, if cost where no object.
