Sway bar questions.
Old 03-31-2009, 10:54 PM
wallyman424
wallyman424's Avatar
Default Sway bar questions.
I'm looking to try some smaller sway bars, since I've upped my spring rates.
Right now I've got big ole springs with the big ole T1 bars, and I figure I can go with a smaller bar to let the suspension do its work. Should I give the C6 Z51 bars a try? Do they even fit a C5?
Or should I just get a set of stock c5 bars? I figure those might be too small, but I'm open to the idea.
Old 04-01-2009, 12:08 AM
LehmanZ06
LehmanZ06's Avatar
A common front bar for the C5 Z06 is like the 32mm front addco bar. Stock is 30.
Old 04-01-2009, 12:45 AM
0Vector Vette
Former Vendor
Vector Vette's Avatar
Pfadt competition sway bars. Adjustability is always a good thing. I have them in stock and on my racecar.
Old 04-01-2009, 12:47 AM
gkmccready
gkmccready's Avatar
C6 Z51 bars should fit the C5. The C6 Z51 front bar is the same as the C6 Z06 front bar. Here're the swaybars I've managed to dig up information from --- accuracy is internet quality since I've pulled it together from the internet:
  • C5 Base: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
  • C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
  • C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness
  • C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness
  • C6 Base: ?? mm-front / 22.0 mm-rear
  • C6 Z51: 31 mm-front / 25.4 mm-rear
  • C6 Z06: 31 mm-front / 28.8 mm-rear
  • Hotchkis: 31.75 mm-front / 28.575 mm-rear / 4mm/4mm thickness $429
  • Pfadt SS Front $550
  • Addco: 35 mm-front / 25.4 mm-rear F: $239 R: $210 Both: $530
  • Pfadt Street: 32 mm-front / 26 mm-rear $845
  • Pfadt Pfatty: 35 mm-front / 28.5 mm-rear $1025
  • C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35mm/6.35mm thick $996
And the obligatory Pfadt chart:
Old 04-01-2009, 08:10 AM
wallyman424
I would love a set of pfadt bars, but the goal of this test is cheapness. If I find that the smaller bars make a big difference, I'll save up for a set of pfadt bars.
btw thanks gmkcc, that helps a lot.
Old 04-01-2009, 08:11 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
I would try to get a set of used C5Z bars and set them up correctly. Since you upped your spring rates, less bar is better.
Old 04-01-2009, 08:27 AM
wallyman424
yeah, I think thats the way Im going to go.
Old 04-01-2009, 09:06 AM
AU N EGL
AU N EGL's Avatar
Wally I have some slightly use C5 Z51 bars just sitting in my basement
Old 04-01-2009, 09:08 AM
wallyman424
oh yeah? that could work. Looks like the rear is the same as the z and the fronts only 2mm smaller.
PM me with what you want for them.
Old 04-01-2009, 09:10 AM
AU N EGL
AU N EGL's Avatar
pm sent call me
Old 04-01-2009, 11:45 AM
bowmanized
bowmanized's Avatar
Looks like you are being well taken care of Wally by your friends. Just wanted to say Eibach just released their new setup.
32mm Front and 29mm Rear
Old 04-01-2009, 12:04 PM
RAFTRACER
RAFTRACER's Avatar
Wally needs the inexpensive RAFT set-up.............
BTW 29mm in the rear with a 32mm front will create LOTS of oversteer........
Old 04-01-2009, 12:14 PM
Aardwolf
Aardwolf's Avatar
I keep reading this thread and wondering if you couldn't just slip some rubber bushings on the sway bar and test out how that does. I'm assuming you have poly. Maybe it wouldn't be a large enough change to tell.
Old 04-01-2009, 12:57 PM
spazegun2213
spazegun2213's Avatar
ummm, this makes me think
Wally, i think i have some C5 z51 bars, although i may have chucked them
Old 04-01-2009, 05:57 PM
Z06Fix
Z06Fix's Avatar
Alright Danny, spill it
Old 04-01-2009, 06:47 PM
gkmccready
gkmccready's Avatar
I've been told my numbers are wrong above... although that makes me nervous because I measured the comp bar numbers off my own bars!
The number provided by Jordan@Pfadt are:
  • Pfadt Street: 35mm-front / 26mm-rear
  • Pfadt Comp: 38mm-front / 32mm-rear
Old 04-01-2009, 07:05 PM
EvilBoffin
EvilBoffin's Avatar
St. Jude Donor '09
yeah Glen, that is what they advertise - so it's worth verifying.
BTW - Did you ever find out what size the Pfadt C5/C6 SS front bar is? If it would help fill out your list, I can go measure mine & report back ...
And remember that there is a specific Pfadt SS front bar for C6Z06's as well, though it seems to have basically identical specs to their front Street bar on the 'obligatory' chart...
To Sway bar questions.
Old 04-01-2009, 10:20 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
And the inexpensive RAFT set-up is??????
Old 04-02-2009, 09:14 AM
TedDBere
TedDBere's Avatar
I've seen Danny drive so I'll take a stab: Disconnect the rear swaybar and drive like crazy.
Old 04-02-2009, 12:44 PM
gkmccready
gkmccready's Avatar
Updated chart:
  • Eibach: 32 mm-front / 29mm-rear
  • Pfadt C6 SS Front: 32mm $550
  • Pfadt C6Z SS Front: 35mm $550
  • Pfadt Street: 35 mm-front / 26 mm-rear $845
  • Pfadt Pfatty: 38 mm-front / 32 mm-rear $1025
It's been explained to me that my original Pfadt Pfatty bars are effectively what are now the Pfadt Street bars and the Comp bars have grown over the years, which explains why they measure out for me differently than the latest and greatest version.
Please remember OD is only part of the story; two 35mm bars can behave entirely different based on wall thickness and arm length!
Quick Reply: Sway bar questions.
