Toe in in degree not 1/16 inch
1 Post
Cruise-In II Veteran
Assume the tire is 26-27 inches in diameter. The tangent of the angle you want is the opposite over adjacent or in this case 1/16 inch over 27 inches. Or do it the way I do since I am lazy, draw a triangle 27 on one leg, 1/16 (.062) on the other and dimension it on your CAD software. The answer to your question is 1/16 toe is equal to .13 degrees. Normally, the nomenclature is total from right to left so "1/16 toe" is half that on each side for a total of 1/16 (1.5mm).
Just make sure you know whether you're using total toe, or toe for each wheel. If you make a triangle out of the wheel diameter and the toe, be sure to cut the total toe in half, like Greg said.
Thanks, no wonder she behaved a little funny, thank good i found out before my next Ring trip.
Also testing out SPA, F1 track, lets see if my cahonas are big enough to stay at WOT down EU DE Rouge
Thanks again
Rune
