A month worth of work... dialup death
Thanks to the Navy I was able to get a couple of weeks back home in Cincinnati for the first time in a LONG time. While I was there, my father and I did some work to the track car getting it ready to finally hit the track. I'm signed up to run at Summit Point in Mid-May and can't wait! In the mean time it is more fun than I ever imagined to have a car like this to tinker with. Thanks to the many of you on here who have answered my ridiculous questions time after time.
Some of the things I did were:
-Installed new Kirkey seats and I/O Port seat back braces with home designed brackets on the seats (machined to perfection as a favor by a friend of my father's). The brackets allow the seat to be low enough to fit comfortably with a helmet and still use the factory mounting locations.
-Installed a new Canton oil cooler (20,500 btu)
-Re-did the ignition system from the ground up after having more problems with it than I care to remember. I'll just say that I am not at all a fan of MSD tech support or customer service. I finally ended up with a Digital-7 box and a Pro Power HVC coil. Made a new bracket and moved the coil farther from the heat to the opening where the battery originally was. It might be a bit of overkill, but a friend gave me a smoking deal on the box after he used it for a grand total of 3 passes at the drag strip.
-Painted the entire interior, installed aluminum panels to cover rear cargo compartments, seat control, radio, and A/C openings, heat shielding on trans tunnel, new heel/toe gas pedal.
-Fixed the front ground effects after they took a pretty good beating in previous track sessions (I'm sure I'll rip them up again shortly)
...and most importantly put the punisher skulls on the pillars just in case it didn't look mean before. Jeff, if you look closely the "Corvettes Anonymous" sticker is now on the rear window behind the number.
Brackets being test fit to the seats.
Ignition stuff...
Interior...
Before:
After:
And Finally...
The rig that made it the length of the WVA turnpike like a champ/ Was hoping to get the trailer painted, but ran out of time.
Ignition stuff...
Interior...
Before:
After:
And Finally...
Of course it wouldn't be too difficult to expand to fit a C5/6 as well. I honestly don't even know if there is a difference. hmmmmmm.....
Figured I'd post this in addition... There was a lot more work than it may look like in the design of those brackets. I originally bought a set of name brand mounts to use. Again, I won't specify since many on here recommended them to me. The second I looked at them I cringed. The engineer in me said there is no way that I am mounting my seats on something like that. The process of creating new ones began and after about a dozen iterations we settled on a design. They were designed to fit any width seat, mounted at any (reasonable) lean angle, and still use the stock studs. We ran quite a few structural analysis on them for different loads and impact conditions and I am very confident that they are much stronger than any other design that I saw. They are single piece 6061 aluminum so they are light as well. Here is a generic example of one of the tests we did... I'm just posting it because these always look cool.
