latch and link harness a big PITA??
Old 04-09-2009, 05:46 PM
dvandentop
dvandentop's Avatar
Default latch and link harness a big PITA??
is the latch and link harness that big of a pain to get the cam lock harness instead?
trying to get one by the weeekend if possible and a close place only has latch and link
Old 04-09-2009, 05:51 PM
FB#1
FB#1's Avatar
PITA compared to the Camlock. My new belts will definately be camlocks.
Old 04-09-2009, 05:52 PM
AU N EGL
AU N EGL's Avatar
Check the tech rules of the club you wish to run with.
L&L are just fine and very secure
Old 04-09-2009, 06:04 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Not a PITA at all, even with a HANS.
Old 04-09-2009, 06:06 PM
dvandentop
dvandentop's Avatar
damn wish i woulda gotten home earlier as i could have had the harness by tomorrow if i had know L&L is not that bad.
oh well guess i will stick with stock belts if i go this weekend
Old 04-09-2009, 06:12 PM
AU N EGL
AU N EGL's Avatar
Your better off with the stock belts.
Harness may seem easy to install, but it does take quite some time to get them installed just right. Plus having all the proper hardware and the harness bar.
Also do your seat backs have holes in for the shoulder harness? Most clubs require shoulder harness to run though seats designed for harness, i.e. race seats.
Wrapping shoulder harness around the seat back is NOT safe idea, and many clubs will not allow this
Old 04-09-2009, 06:14 PM
dvandentop
dvandentop's Avatar
I have carvaggio race seats with sharkbar and also the vettworks lap mount bar. so i am setup properly, just need the harness to complete everything
AU N EGL
AU N EGL's Avatar
Old 04-09-2009, 06:17 PM
fej
fej's Avatar
I went camlock for the driver, since I am in and out of them a bunch, and will be picking up a L&L for the passenger side.
Fej
Old 04-09-2009, 06:18 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
Get a pull up harness. Although the lap belt straps are longer it is much easier to adjust the lap belt with pullup Vs pulldown. With pull down the inside belt is impossible to adjust once in the car and the outside belt requires having the door open and a very long arm.
Bill
Old 04-09-2009, 06:21 PM
Aardwolf
Aardwolf's Avatar
No trouble with the L&L in mine, I'd get them again.
Old 04-09-2009, 06:51 PM
UstaB-GS549
UstaB-GS549's Avatar
I hooked my watch band on the latch one time in a parking lot autocross and unlatched my belts. Probably a fluke, but I replaced it with a cam lock when it died of old age.
Old 04-09-2009, 07:44 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
It is not that bad, and they are totally safe, just an inconvenience. The camlocks are easier, but the round ones are less likely to have an accidental release than ones with a lever type release.
Old 04-09-2009, 08:15 PM
PA Z06
PA Z06's Avatar
I have team techs camlocks, and they are much nicer the l/l,
Old 04-09-2009, 08:32 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
As an instructor I had the opportunity to ride in a car with a cam lock and a latch lock.
That latch was a pain, simple but still a pain.
When I get the belts for my car it will be a cam lock.
Old 04-09-2009, 08:34 PM
mousecatcher
mousecatcher's Avatar
Default rollover
isn't there a difference if you are upside down? camlock may be more difficult to undo given the tension on the buckle, is what i hear.
i've used both and don't know which i'd prefer upside down. certainly right-side-up the camlock is cooler.
Old 04-09-2009, 08:46 PM
RusherRacing
RusherRacing's Avatar
I have cam lock belts now but I don't mind latch and link. My old one's were latch and link. My next ones probably will be latch and link because the price difference doesn't seem worth it in my opinion. I would rather buy a higher quality latch and link system than than a cheap camlock.
To latch and link harness a big PITA??
Old 04-09-2009, 09:23 PM
zeeohsix
zeeohsix's Avatar
I've had both types, and I don't think there is any problem releasing a camlock upside down. Anyway, just keep the wheels pointing down and you'll be ok!
Old 04-09-2009, 09:39 PM
fatbillybob
fatbillybob's Avatar
There is one huge advantage in LL when it has a longer tongue for 2 substraps, that means room for 2 shoulders & 2 subs. When you get the 2 substrap LL you have a true 6pt harness that won't crush your nuts like a V or T sub on a camlock. In fact a V or T substrap is not a great 6 point sub. Most importantly however is that you have the most direct control over the lapbelt (which is the purpose of the subs) because the subs are directly attached to the LL. The only other camlock that can claim this is a very expensive scroth hybrid cam. Even if you use a 6pt forumla style camlock that true 6pt sub will not act on the lapbelt as quickly as the LL or a scroth hybrid. So, If I was buying a harness today it would be a 6pt scrotch hybrid first then a LL 6pt then anything else 3rd.
Old 04-09-2009, 09:46 PM
ghoffman
ghoffman's Avatar
Teamtech has the same arrangement and then takes it one step further with the Jetpilot harness. I am only saying that even though I don't like the latch type, there is really nothing wrong with them.
Quick Reply: latch and link harness a big PITA??
