New shoes!
Old 04-09-2009, 10:14 PM
XPC5R
XPC5R's Avatar
Default New shoes!
Some new Hoosier radial slicks, we'll see how they compare to the trusty A6's
Old 04-09-2009, 10:37 PM
63Corvette
63Corvette's Avatar
I for one, would really like for you to post your comparison with the A6 tires.
Thanks,
Old 04-10-2009, 02:26 AM
EvilBoffin
EvilBoffin's Avatar
St. Jude Donor '09
Originally Posted by 63Corvette
I for one, would really like for you to post your comparison with the A6 tires...
Me too... Very interested if it's a fair comparison (car in similar state of tune & alignment, tire sizes similar, etc.).
Thanks!
Old 04-10-2009, 11:52 AM
XPC5R
XPC5R's Avatar
I'll be swapping them between my current set of A6's (285/335) at next weekend's autox. We have had a few years on A6's, so I think I'll be able to feel a difference. Hope I can get enough heat into them for a fair comparison.
Old 04-10-2009, 12:40 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
Are you going to be running with us up at La Grave field next Sunday?? I really enjoyed watching you blitz all of us out at MW last year!
Have a good one,
Mike
Old 04-10-2009, 02:19 PM
RAFTRACER
RAFTRACER's Avatar
I am interested to see how this works out also Stan....Please report back..
Old 04-10-2009, 03:52 PM
Ernesto Roco
Cruising
Ernesto Roco's Avatar
I tried out the new Hoosier slicks and I like it a lot.
On my first session with the slicks I was just tip toeing a bit to get used to the tires. I was immediately within range of my best times using the trusted A6 tires.
Immediately I noticed that they had great feedback to the driver so you can definitely drive these tires harder. I lost a little bit of forward bite but I thikn the setup needs to get adjusted to get it back.
They also came out with a new size which will fit better on my wheels. The 305's that I tried were a little narrower than the 315's I had and almost an inch narrower than the 335's.
Check out the video of my first few laps with the slicks.
http://www.youtube.com/watch?v=OrTxTRr5Z2E
I had the wrong gear for the track and was trying to keep the rpm's somewhat low because I still don't have a dry sump nor do I have an Accusump for the car. I still spun a bearing though on the following day
Old 04-10-2009, 05:53 PM
XPC5R
XPC5R's Avatar
Have a good one,
Mike
I was planning on the SCCA event at Pennington Field on 4/19.
Good to hear they work decently and have good feedback. I hope I don't loose forward bite though. The rears are going to be taller than my current ones, so that should help, very close in size to the 315/345 setup I ran last year.
Old 04-10-2009, 09:49 PM
Racin Jason
Racin Jason's Avatar
Awesome. Really looking forward to hearing how they do in comparison to the A6's.
Can't really tell from the pictures, but what sizes are they?
Also, what wheels will you be running them on?
Old 04-11-2009, 07:43 PM
XPC5R
XPC5R's Avatar
305/645/18 front, 315/690/18 rear, will be mounted on 18x11.5 fronts, 18x12 rears for now. 18x12 and 18x13 if they need it later.
Old 04-11-2009, 07:48 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Do they make 345 rears?
Old 04-11-2009, 08:06 PM
0C5stein
Former Vendor
C5stein's Avatar
Hi Gary,
They have more sizes coming out this year, but for now this is it in 18"
Tire Size - TreadWidth - Dia Approx. - Circ Recom. -Rim Measured
Rim Section
Width
250/650R18 9.1" 25.6" 80.4" 8-9.5"
265/645R18 10.1" 25.5" 80.0" 9-10"
280/680R18 10.0" 26.9" 84.6" 9-11"
285/645R18 10.9" 25.5" 80.0" 10-12"
305/645R18 11.8" 25.6" 80.6" 11-13"
320/650R18 12.0" 25.7" 80.75" 11-12"
305/30R18 VRL 11.6" 25.6" 80.5" 11-12" Viper Spec tire
315/690R18 12.3" 27.3" 85.6" 11-12"
335/30R18 VRL 12.6" 25.6" 80.5" 12-13" Viper Spec tire
310/710R18 12.4" 28.1" 88.4" 10-12"
Let me know if you need any
MSI is a Hoosier Direct Dealer
Old 04-29-2009, 08:08 PM
Racin Jason
Just wondering if you ended up doing this, and if so how they compared?
To New shoes!
Quick Reply: New shoes!
