T1 Bar settings
Old 04-14-2009, 06:56 PM
Lan.Jet
Lan.Jet's Avatar
Default T1 Bar settings
I have recently install T1 bars in my C5 I set the rear bar to the center hole. I now have a little over steer. Should it be moved to the inside hole or outside to correct this. Am I correct in thinking the outside hole is the softer setting.
Old 04-14-2009, 07:10 PM
mountainbiker2
mountainbiker2's Avatar
Outside.
Old 04-14-2009, 08:07 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
You are correct. Outside.
Old 04-14-2009, 08:11 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
anybody have an adjustable T1 rear bar off that could measure the distances from the end link holes? I'm curious to see what the measurements are from wide to wide, center to center, and inside to inside (from center of hole to center of hole).
Old 04-14-2009, 08:35 PM
Lan.Jet
Lan.Jet's Avatar
Thanks for the replies.
DrivinHard if you don’t get a measurement by Friday I will get one when I change my settings
Old 04-14-2009, 09:10 PM
davidfarmer
davidfarmer's Avatar
moving furthest from the torsion bar increases the cars leverage against the bar, effectively making the bar softer. I think it's great they made the T1 bars adjustable, they never were back when I ran them
Old 04-14-2009, 09:36 PM
drivinhard
drivinhard's Avatar
yeah I've got an older set that isn't. that's why I was curious to see what the hole measurements are, to compare to what the old style rear works out to be. (I'm assuming the dia and thickness of the bar stayed the same)
Old 04-14-2009, 11:23 PM
sperkins
sperkins's Avatar
I'll try to remember to get those numbers for you tomorrow.
Old 04-15-2009, 12:34 PM
JRL
JRL's Avatar
Default T1 Bar Settings
I just changed from the old rear bar to the adjustable. The hole in the old bar is equal to the middle hole of the new bar. Makes sense, so you can adjust both directions of stiffness.
JRL
Old 04-15-2009, 01:12 PM
froggy47
froggy47's Avatar
So the longer the bar (hole to hole) is the same as running a softer/thinner bar
shorter the bar (hole to hole) is the same as running a stiffer/thicker bar
Sorry if this is noobish, but I want to be clear.
Old 04-15-2009, 07:18 PM
Lan.Jet
Lan.Jet's Avatar
I measured on top of the bar center to center outside hole 43.5 center hole 42.25 inside hole 41.
Old 04-15-2009, 07:46 PM
drivinhard
drivinhard's Avatar
JRL
that's kinda what I figured (it would be the center one)
thanks
Old 04-15-2009, 09:23 PM
sperkins
sperkins's Avatar
You beat me to it by a couple of hours. Thanks for the info.
So for a recap:
Outer most holes = tighter / more oversteer
Inner most hole = softer / less oversteer
Right?
Old 04-15-2009, 09:41 PM
gkmccready
gkmccready's Avatar
Originally Posted by sperkins
So for a recap:
Nope. The longer the lever arm, the "softer" the bar is. The shorter the lever arm, the "stiffer" the bar is. As for over/understeer, it all depends which end of the car you're adjusting...
Old 04-16-2009, 03:54 PM
froggy47
froggy47's Avatar
Well crips,
We got a whole bunch of us "senior forum members" and the adjustment of a sway bar is still not clear.
How about it guys? Which way?
Old 04-16-2009, 04:06 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Correct.
Old 04-16-2009, 04:11 PM
gkmccready
gkmccready's Avatar
http://www.buildafastercar.com/tech/...ate-Calculator
Plug in some numbers and see. The longer arms give the suspension more leverage against the bar. Shorter lever arm, less leverage, bar gets stiffer. Longer arm, more leverage, bar gets softer. You had it right in comment #10.
To T1 Bar settings
Old 04-16-2009, 04:12 PM
froggy47
froggy47's Avatar
On my way to MARK the bar.
Thanks.
Nice link, added to my fav's.
Old 04-16-2009, 04:20 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Moving the link to the outside hole will cause the bar to get softer. Which should help the OP's oversteering problems.
Randy
Old 04-16-2009, 08:20 PM
mountainbiker2
Thanks.
Adjustable swaybar on a SS car? Hmmm
Quick Reply: T1 Bar settings
