NT555R2, Lapping Day / AutoX tire pressure?
Old 04-20-2009, 04:41 PM
Jameel
Jameel's Avatar
Default NT555R2, Lapping Day / AutoX tire pressure?
As the title says, what should my cold and hot tire pressures be for a lapping day and Autox on set of NT555R2 (275-17 front, 305-18 rear)?
The tires are mounted on stock rims on a C5Z06.
Thank you.
Old 04-20-2009, 04:44 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Hot about 36 PSI
Old 04-20-2009, 05:15 PM
Jameel
Jameel's Avatar
Originally Posted by L98Terror
Hot about 36 PSI
Front and Rear?
And for both AutoX and Lapping days?
Thanks.
Old 04-22-2009, 08:53 AM
mark b
mark b's Avatar
I agree dont go higher then 35 hot, they get too slippery... keep them at 28 to 30 cold then check pressures each session and adjust so you stay at 30 or 32...
Old 04-22-2009, 10:45 AM
sperkins
sperkins's Avatar
I had good luck with mine at 28/30 cold. Rears would get to about 33-34 hot depending on the track and ambient temps. At autocross, I started a pound or two lower since you can't really heat them up. If tire life is a concern, go with higher pressures as L98Terror said.
Tip - be sure to rotate side to side or you'll wear the L/F faster on most road courses.
To NT555R2, Lapping Day / AutoX tire pressure?
Quick Reply: NT555R2, Lapping Day / AutoX tire pressure?
