Anyone tried the HT-10 pad for street/track use?
I put on these Hawk HT-10 pads expecting them to be cold and not stop well but got a big surprise. Barely touching the pedal will lock up the front! They have amazing cold bite. They would be bad for a rain event so I'm taking along some stock type pads too. If I'm careful they do modulate well but a quick stab to the pedal is a
They squeal and dust like crazy! They definitely are a good pad for driving to the track though.
Found a cool chart of temps and torque for Hawk pads:
http://www.andrew-racing.com/compoun...on%20chart.pdf
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Sounds like a good track pad. Blue and black pads are not recommended for street use and the HT-10 is more aggressive. I would not use them on the street but thats just my opinion.
Yeah the squealing really is extreme. I'll be changing them out when I get home from this weekends event. I had to laugh at the dust, I went to get an alignment and the front wheels turned black. They are definitely safe to drive with though, no cold laggy stops.
I've got some DTC-60's and my tires are scared to try them! :lol
I change to race tires at the track, even when trailered sometimes, so I also swap out the pads at that time since its easy enough. I use Advance Auto "Silver" pads for the street cause they are only about $20 an axle, and I dont want to use the track pads when I dont have to. I am going to try the HT-10 on the front and Black on the rear for the track this year.
1200F isn't really high enough.
I consumed a set of HT-10's on my second-ever HPDE (stock GTO brakes,
basically the same as C5's).
I consumed a second set on my third HPDE.
Got two days out of a set of DTC-60's with a single duct.
State of the art at present is 2.95 days out of a set of DTC-70's with dual 3"
ducting and 13" stoptech's with st-40 calipers.
My next victim is a set of PFC97's - am hoping to get at least 3.01 days from
those.
If you have ducting and aren't insanely hard on the brakes then the ht-10's
are pretty good bang-for-the-buck - they're significantly cheaper than the
DTC pads. But they disappear fast once the rotors get up to around 1500F.
those.
Received 8,928 Likes
those.
those.
Bill
those.
those.
Former Vendor
Safe perhaps but I'll wager half that dust is your rotor and not just the pad. Running such high Cf pads at cold temps tends to eat rotors for breakfast.
Wow - driving style/speed produces some radically different experiences with regards to pad life. Last year in my 07 Mustang I did 13 HPDEs, about half in Novice group and the other in Intermidiate. One set of HT-10s on the front (2 sets of rotors). That's a 3500lb car and the fronts are a bit smaller than the C5, note it does have brake ducts. Granted I'm not the fastest guy out there but I'm not that slow either. Just easy on brakes I guess.
I agree with the OP, they work fine when cold, squeal and dust something fierce. I frequently used them to drive to events.
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I'm kind of slow but....
those.
those.
I wouldn't do it with the DTC70. Like Todd_TCE said, I'll bet half the dust is the rotor being eaten... Those pads got pulled right after I got home. If you are running street tires they probably should be afraid of the DTC pads. I ran a few sessions on old GY F1s and the pads overload them real quick. You have to be real sensitive with the brake pedal pressure or you'll be all over ABS. Now on slicks, much more fun ;-)
