Best track tire with stock rims and factory alignment?
Old 04-22-2009, 12:58 PM
psft_alum
psft_alum's Avatar
Default Best track tire with stock rims and factory alignment?
>>Expanding the audience for this thread>>
For my 2008 C6 Z06, I have an extra set of OEM C6 Z06 wheels and would like to mount tires specifically for HPDE track use. I thought Hoosier R6's were the ticket until I learned that they require a great deal of negative camber.
Members have suggested
- Michelin Pilot Sport Cups
- Kuhmo Ecsta XS
- Kuhmo Ecsta V710
Please give me your educated opinion for my ideal track tires based of this criteria:
1) stock rims
2) stock sizes or close - no AH/TC issues or rubbing
3) one alignment that will work for street and track tire sets
4) can be run flats or not
5) available by first week of June 2009
Thanks in advance!
Old 04-22-2009, 02:58 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
One vote for Nitto 555RII in sizes 275/40/17 & 305/35/18.
Front Alignment -1.8 camber, 7 degrees camber (same both sides), 0 to 1/32" max Toe IN
Rear Alignment -1.2 camber, 1/16" to 3/32" Toe IN
Old 04-22-2009, 03:05 PM
sperkins
sperkins's Avatar
I loved my last set and they lasted nearly a whole season (or about 10 events with lots of street miles).
Old 04-22-2009, 03:14 PM
63Corvette
63Corvette's Avatar
If you want to be competitive, and/or have a chance to place, then Hoosier A6 is your only choice. (But they'll wear out without lotsa camber)
If you only want to compete, then the Nitto NT-05 or (as mentioned above) Nitto 555RII will work fine.
Old 04-22-2009, 04:44 PM
AlwaysInBoost
AlwaysInBoost's Avatar
another vote for the 555rII's.
Old 04-22-2009, 05:24 PM
95jersey
95jersey's Avatar
He is actually talking about a C6Z, not C5. I responded to his thread in the C6Z section.
I suggested he try Kuhmo 710's with rounded shoulders vs Hoosiers.
Old 04-22-2009, 06:54 PM
Sidney004
Sidney004's Avatar
V710's. They are very camber tolerant and a very good tire.
Old 04-22-2009, 09:59 PM
mrc24x
mrc24x's Avatar
Another vote for the V710. Great tires for what you want. You won't give up much vs the A6 but they last much longer. Give Stupidfasttires.com a call.
To Best track tire with stock rims and factory alignment?
Quick Reply: Best track tire with stock rims and factory alignment?
