SPRING SPECIAL! –C5, C5 Z06, & Base C6 Competition Brake Cooling Ducts ONLY $100
Old 04-22-2009, 05:20 PM
0Lambert_Automotive
Former Vendor
Lambert_Automotive's Avatar
Default SPRING SPECIAL! –C5, C5 Z06, & Base C6 Competition Brake Cooling Ducts ONLY $100
Our lowest price on these spindle ducts EVER!
These ducts are designed to the C5, C5 Z06 and C6 equipped with the base model braking system. These will fit a C6 Z51 but the gap will be larger around the center of the rotor.
This special is limited to only 5 kits.
Now for some more info on the kit:
The kit includes everything pictured above plus fasteners and instructions. NO HOSE INCLUDED. If you need hose enquire at the time you order.
A link to the kit on our website HERE
The plates were designed in SolidWorks using CAD data direct from GM. Fit and finish is perfect.
Plates are made of 1/8” thick 6061-T6 aluminum, and the tube is 3” O.D. 6061-T6 with 1/8” wall. Welding process used: TIG. These will not bend, flex or break!
They install without removal of the hubs and use existing holes as mounting points. We supply an additional support bracket, (shown on the back side of the spindle) to secure the duct near the caliper.
We assure you they are VERY simple to install.
You will not find a higher quality duct for the Corvette.
08112.DK - Duct Plate Kit - $100.00 + Shipping (SAVE $25)
Hose is not included in this kit. If you are in need of hose please inquire when you place your order.
We accept all major credit cards and even have a toll free number: 1-888-422-9685.
To place your order give us a call and hit extension 1. Tell us that you want to order 08112.DK Corvette Forum Special.
Remember we are limiting this special to 5 kits. After we get 5 orders that’s it. So get your order in early!
Finally please remember C5 cars not equipped with Doug Rippie Motorsports ducts will require them, base C6 cars not equipped with C6 Z06 ducts will require those as well to make these ducts completely functional.
Thanks,
Jon Lambert
Quantum Motorsports
Old 04-22-2009, 06:55 PM
dvandentop
dvandentop's Avatar
good kits! i got them for my z06.
Old 04-23-2009, 11:50 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
How or where do the ducting hoses attach?
DRM ducts or?
If to stock ducts - how is ducting hose routed to avoid wheel?
I looked at the web site but didn't see pics of ducting hose installation.
EDIT ... nevermind! ...
this must be it ...
Modified C6 Z06 Inlets
Kit Features:
We take stock Z06 inlets and modify them to match airflow of our 3" hose. We also include all mounting hardware instructions and a template for cutting your stock C6 fender well to accept the Z06 ducts.
Old 04-23-2009, 01:59 PM
DarkMastyr
DarkMastyr's Avatar
Pics of the ducts I got from Jon. These new ones look a bit different in design, but I can say the fit and finish is quite good.
Old 04-23-2009, 05:54 PM
0Lambert_Automotive
Former Vendor
Thank you sir!
This is a great price guys. Don't miss out!
Old 04-27-2009, 04:01 PM
0Lambert_Automotive
Former Vendor
Only one left!
Old 04-27-2009, 06:28 PM
Leo z51
Leo z51's Avatar
I will take the last one.
Old 04-27-2009, 07:01 PM
0Lambert_Automotive
Former Vendor
Give us a call to place your order. 888-422-9685
To SPRING SPECIAL! –C5, C5 Z06, & Base C6 Competition Brake Cooling Ducts ONLY $100
Quick Reply: SPRING SPECIAL! –C5, C5 Z06, & Base C6 Competition Brake Cooling Ducts ONLY $100
