"I can't drive F55"
Old 05-10-2009, 09:37 AM
naschmitz
naschmitz's Avatar
Default "I can't drive F55"
Did my first track event at Summit Point last weekend with my 2006 with magnetic selective ride F55. I used with this setup for two years of high speed autocrossing on abandoned runways, so I know how to generate decent cornering and braking forces with the car.
With the elevation changes at Summit Point, I rubbed holes in all four plastic fender liners because the springs and shocks are so soft, even in "Sport." The track photographer got some shots of me in a braking zone where the black plastic front air dam is in contact with the roadway across it's entire width.
Going to fix it by installing a set of HardBar dual rate coil overs and Penske two way adjustable shocks. I've ridden with Gary Hoffman in his C6Z06 with this setup and it rides very nicely on both the street and the track, so I doubt that I'll miss the F55.
I'll post pics of the install after I receive the goods.
Old 05-10-2009, 11:42 AM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Wayne O tracked his F55 for a long time and really liked it on the track. He had Z06 sway bars, then latter went to wider wheels and bigger tires and T1 bars.
However....he's been progressively turning the car into a track only machine and finally switched over to either regular shocks or coil-overs. Contact him (or maybe he'll pop into this thread) if you have any questions about the conversion.
I believe he had to go to the dealer and get them to use a Tech 2 to "de-program" the F55.
Bob
Old 05-10-2009, 12:06 PM
Z11409
Z11409's Avatar
F55 can be defeated by installation of a small resistor in the shock end of the wiring.
Old 05-10-2009, 01:50 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Your ready to junk your stock suspension after ONE track day???
Old 05-10-2009, 02:24 PM
longdaddy
longdaddy's Avatar
lowered the car too much?
Old 05-10-2009, 04:36 PM
naschmitz
naschmitz's Avatar
I could keep doing additional track days and rubbing the tires against the fender liners, but doing the same things and expecting a different result is the definition of insanity, is it not?
Old 05-10-2009, 04:38 PM
naschmitz
naschmitz's Avatar
Thanks for the idea. Any guess on the value of the resistor needed? Four resistors is far cheaper than having the dealer hook up the Tech2 to delete the F55 option.
Old 05-10-2009, 04:55 PM
naschmitz
naschmitz's Avatar
Bob
Thanks, Bob. By the way, thanks again for the TPMS tool help you gave me a few years ago. I have TPMS sensors in all my wheels -- which is good since I had a nail in my tire driving home from Summit Point and the TPMS saved me. I made it home the last 300 miles by inflating the tire to race pressure (42 psi) and watching the TPMS until it hit 26psi. That got me 90 miles between air fills. Four air stops and I was home. I love TPMS!
Bert
Old 05-10-2009, 06:14 PM
Z11409
Z11409's Avatar
I have used many sets of 5 W/15 OHM without a problermo.Ceramic resistors at about $4-$5 for a set of 4. Needless to say trim wires,tape and waterproof well. Consider just changeing to the PFADt shocks and bars.
Old 05-10-2009, 09:16 PM
RattlerC5
RattlerC5's Avatar
Default F55 Delet
The F45 can be handled with the resistors, but the F55 has to be programed out. My dealership handled it with a Tech II and less than 90 minutes.
I have gone to Pfadt coilovers and couldn't be happier. I was told I would need a very sharp tuner with access to upgraded GM software and the going rate on the left coast was $650! It really had more to do with islolating the suspension module and telling the BCM not to look for it. One hour labor and I was on my way to RSD for my coilovers.
No codes and no performance issues.
Old 05-10-2009, 09:55 PM
BrianCunningham
Why don't you try that?
You want wheel travel even with the coilovers
If the car is lowered too much, then the suspension will be too stiff, like a gokart.
Old 05-11-2009, 12:13 AM
tmak26b
tmak26b's Avatar
I was using the Z51 stock setup, even now I am giving up on it with stiffer shocks. The R comps and the aggressive brake pads really show how soft the car is. I already spent $100 fixing wheel liners from car rubbing, I guess spending $1K on shocks will fix it
Old 05-11-2009, 07:49 PM
naschmitz
naschmitz's Avatar
Brian,
It isn't an issue with ride height nor am I planning to change the ride height -- the springs and shocks are waaay too soft for how hard I am driving the car. If you are at NHMS on the 21st you'll be able to see it or if you are at Devens on the 31st I can take you for a ride.
Bert
naschmitz
naschmitz's Avatar
Yup!
Old 05-12-2009, 08:50 AM
BrianCunningham
I'll be at Devens on the 31st.
Love to go for a ride
Old 05-12-2009, 12:44 PM
Wayne O
CF Senior Member
Wayne O's Avatar
Bob
True enough but in all fairness the tracks I generally run on don't have a lot of elevation changes. On the flatter road courses I was actually surprised with how well the F55 suspension performed (at least considering the bad 'track press' the F55 often gets). Track performance became the priority and I did switch to LGM coil-overs and T1 bars which is unquestionably a better track setup. Yes, the Tech 2 tool was needed to de-activate the F55 and render it dewat.
We have a new track facility opening soon in southern Arizona with a 2.75 mile road course including 100 ft of elevation changes...can't wait!
Old 05-12-2009, 01:20 PM
BrianCunningham
The bigger issue is for people like Bert & I who do both autox and track events.
Generally you run much stiffer springs/shocks for autoxing
I've been doing the 'using shocks as springs' deal for 10years with my soft base suspension.
I'm really looking forward to upgrading it to coilovers. the dual rate springs I'm putting on should help things out.
To "I can't drive F55"
Old 05-12-2009, 07:38 PM
tmak26b
tmak26b's Avatar
There is no such thing as a flat road course in the northeast
Old 07-12-2009, 09:40 AM
naschmitz
naschmitz's Avatar
Default Pictures of double adjustable Penske 8300 with HyperCoil dual rate springs
The dual rate springs combined with the adjustment range available on the Penske's provides a good ride over the New England crappy roads -- not a Cadillac ride, more like a BMW sports car ride. The handling improvements are dramatic. The cost of this mod was comparable to the cost of long tube headers with high flow cats and exhaust -- in retrospect, I should have done this mod FIRST.
Thanks to Gary Hoffman at HardBar and Richard Strout at Leading Edge Motorsport for all the personal attention and advice provided for the parts selection and installation.
Front Sorry for the dirt
Rear
Front canisters
Rear canisters mounted in storage bins
Old 07-12-2009, 12:28 PM
BEZ06
BEZ06's Avatar
Hey Bert - that looks like a great setup!!
Did you end up needing to use a Tech 2 to tune the F55 out of the system?
Bob
Quick Reply: "I can't drive F55"
