AMB Transponder?
Old 05-11-2009, 06:08 AM
varkwso
varkwso's Avatar
Default AMB Transponder?
Any leads on a used one - or a cheap place to buy a new one?
thanks
Old 05-11-2009, 10:20 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I wasn't able to find one used a couple of weeks ago.
New rechargeable was $430 with shipping from hoerr (sp) racing through amazon.
I think the wired was $390 shipped.
I just went ahead and bought it, it showed up in just a few days.
Old 05-11-2009, 11:10 AM
Z06cool
Z06cool's Avatar
A bit cheaper plus free ground shipping.
http://www.pegasusautoracing.com/group.asp?GroupID=AMB
Or see if DiscoveryParts is cheaper with the "Sparkle Pony" discount.
Old 05-11-2009, 11:12 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Go ahead and buy 1 new so then a used will come on the market the day after you get yours.
Old 05-11-2009, 01:43 PM
imp zog
imp zog's Avatar
Unless you have two cars with you at the track, I'd just get the wired model for reliability and use an "add-a-circuit" connector to get it powered and you can, literally, take it off and mount it on another car in about 5 minutes. For a super-quick install this weekend I attached it in the front passenger wheel well on the front inside of it just under the brake duct, using one of the existing trim bolts as well as regular screws just holding it to the plastic trim. I'll likely search for a better spot for it, but you want it up front of course, because it would suck to lose by the length of your car because you mounted it in the back!
Pick a switched fuse in the under-hood fuse block, so that the transponder is off when the car is off, and find a grounding bolt and you are good to go. I picked one of the O2 sensor fuses because a) it still allowed me to put the cover back on the fuse box, and b) I don't have the O2 sensors there any more anyway because the race series has a no cats policy. Realistically though, just about any will do, the AMB draws so little power that you can put the add-a-circuit in just about any of them. The little green light should be off when the key is off, and on when the ignition is on. The only trick was finding a good ground bolt to attach to within reach of the ground line, darned plastic car has very few close to the fuse box on my C5 Z06!
Old 05-11-2009, 02:23 PM
WBHighwind
WBHighwind's Avatar
Are yall using the 260 or the 160? I have a 160 left over from my karting days.
Old 05-11-2009, 02:30 PM
imp zog
imp zog's Avatar
I'm using the TranX260 direct wired model. Actually, I'm using a friend's 260, hence the wiring tutorial I left above; I'm holding out for the used one that Jason said is likely to come up for sale after varkwso buys his!
Old 05-11-2009, 05:03 PM
95jersey
95jersey's Avatar
With the popularity of GPS devices, you can find the XT or Longare Hot Lap Timers on e-bay for 1/3rd the retail price. I won a bid for a perfect shape XT for $99.00 I think they are $250ish new?
Can't see spending any money on new when there are SO many of these used on e-bay. Take advantage of most racers going GPS and buy their used stuff.
Old 05-11-2009, 05:22 PM
AU N EGL
AU N EGL's Avatar
AMB transponders are used for official timing by clubs and tracks have the loop in place.
for personal timing that is different.
any SCCA or NASA races or NASA TT, the AMB is a must have
Old 05-11-2009, 06:19 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Jeff knows this but for everyone else:
Do not wire your transponder to your daytime running lights. They turn "off" when you turn your parking/headlights on.
Old 05-11-2009, 06:32 PM
imp zog
imp zog's Avatar
Okay, I gotta laugh at that one, especially when some races require lights on when there's rain, and that's the first time you notice it! Ouch!
Edit: I laugh only because that sounds like something I would have done!
Old 05-11-2009, 06:37 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Yeah, we were at Rd Atl last year in December and it was getting dark and I thought I'd turn my parking lights on, safety first right?
Old 05-11-2009, 06:43 PM
SIK02SS
SIK02SS's Avatar
check Ebay and racingjunk.com
Old 05-11-2009, 07:19 PM
varkwso
varkwso's Avatar
that is why I keep putting it off.
I did have two - then the owner of both started racing again so I had to return one - soon his son will start racing again and will want the second one back
I hope to have two cars at the track when I can and want to get two of my very own - swapping takes time better spent resting up for us old guys.
Old 05-11-2009, 08:46 PM
Z06cool
Z06cool's Avatar
Originally Posted by varkwso
...time better spent resting up for us old guys.
Do you think it really matters you old geezer...
Old 05-12-2009, 06:31 AM
varkwso
varkwso's Avatar
you should be resting - you have a big day planned, today.
Old 05-12-2009, 07:35 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
And about damn time I'd have to say.
To AMB Transponder?
Old 05-13-2009, 03:19 PM
varkwso
varkwso's Avatar
it got busier
Old 05-13-2009, 06:55 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
it got busier
Heading home soon. Call if you hear anything. Will be up late.
Old 05-13-2009, 08:25 PM
varkwso
varkwso's Avatar
you guys will know when I know anything....
Quick Reply: AMB Transponder?
