Entry Level Race Brake Pads for Stock Calipers?
Terminal Vette Addict
Updated after the Initial Comments:
Road courses, HPDE, etc.
For clarification, Im on my second season. And as of event #2 for the season I've exceed the tolerances of street quality pads. 20 min on Pocono North, and I ahd to start increasing my brake distance for the last 5 laps... on SS lines, Recent flushed with Motul RBF 600, year old + calipers, baers in the front and OEM in the rear rotors, ECS front brake duct cooling kit.
I am on Hawk Ceramic Performace Street pads NOW, and Im at the level now that Im running way too hot on them & they are fading. I do not need $400 fronts and $300 rears that do 1800 degrees... but i need something for the track that I can could on during session 6+ in a single day. And then Again the very next day.
Stock OEM will not do, moved out of those last year by season end. Do i just jump up to HPS? HP+? DC60? Other brand? One of the other higher temp pads. I don't want them to bite to hard too fast.. or chew up my rotors too quick... since these will be for track days and I'll be swapping a bit of noise is not a worry. Prefer not to have to sho pvac my rims, but i know more dust is coming when i go to a race pad.
CCW Classics & Michelin Pilot Sport Streets 18/275 & 18/335
Suggestions?
Suggestions?
stock c5z06 brake pads will work just fine for your first few events
Brake dust WILL be a lot with are real brake pads that you need to use to stop your car.
That is just part of the game. and the only thing to do is wash the wheels and car
I'm using the Carbotech XP10/XP8 combo and I'm surprised at their street manners. They are quiet and the cold stopping power is just fine. I wouldn't go so far as to recommend them for full time street duty but driving to and from the track they work just fine. (Note I have the Carbotech bobcat street pads for daily use). I have 4 track days on them and thus far they seem to be easy on the rotors. No fade, no problems. The only thing I don't like about them is they don't have a lot initial bite, seem a little soft to me. Last year I used the Hawk HT-10 - they were louder but had better bite. I'll go thru these pads before passing final judgement but I may step up to XP12/10 next time. All track pads dust, just one of those things you have to live with if you want great stopping power and no fade.
Not sure if your question was aimed at me but if so: I use ATE Superblue and bleed every event. When I used the word 'soft' I didn't mean the pedal is soft, I meant the Carbotechs don't have as much initial bite as some of the other pads I've used. With the Hawks, they grabbed right away with medium pressure. The Carbos take more pressure. I'm not complaining - they stop the car just fine, I just liked the feel of the Hawks a little better. I'm comparing different cars though, so maybe its not a fair comparison (although I used the Hawks in a car that weighed several hundred pounds more).
FYI.....We have been selling a lot of Performance Friction 99 compound for the front with the Z rated rears. Great performance and great bang for your buck.
-Michael
-Michael
Im on Motul RBF 600 and did a complete system flush prior to the event. SS lines, and newer (year + old calipers). I tried the stock z06 pads, they did worse than the hawks performance street ceramics for stopping. I really need to jump up a notch to something that will stop harder and hold the heat better... but i dont need the crazy ridiculous1800 degree pads either.
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I wouldn't go to that (ht10/dtc60) combo unless you are running soft compound tires. (they tend to lock the tires easy on street tires)
HP+ hawks are plenty of pad for street tires, especially if you add cooling hose on the fronts.
I'm using Cobalt XR1 in front, XR-1 in rear (using R compund tires) and really happy. The next problem for me then became heat (adding braking capacity unfortunately creates new possibilities to spend $ Installed DRM's brake duct system and an adapter to hook it up to the brake rotors in the front so I'm pretty happy now.
/Hakan
/Hakan
I have been running the hp+ for 4 events now and i am not happy with them, they stop well for about 4 laps, then the heat makes them alot less effective in hauling the car down, no confidence and no short brake zones, they scrub speed ok, but the tracks i run go from high speed to hairpin to high speed. Go to the hawk ht-10 min, or as the pfc guy said the 99 you might not need the 01. If you can spend the bucks dtc 70/60 f/r. Call phoenix racing.
To START off with your first few events, stick with the simple yet proven.
the Stock GM C5Z06 brake pads.
the Hawks are great brake pads once you really get into these events. which you will
they DUST like an Oklahoma dust storm. and eat paint if the brake dust gets wet.
Plus most of those brake pads mentioned above are not really street pads
I also use the Carbotech XP10/XP8 for HPDE's - Great pads. I am in the advanced run group and they hold up well, are easy on the rotors and are not corrosive to the wheels.
Just my HO, I think the C5Z pads are terrible track pads, even for a newb or fairly newbie. They WILL fade, and they don't last at all. I have worn out a set in 1 day and was not pushing 10/10ths.
If you are already having fade problems at pocono, I think you need a better pad than OEM. You can probably get by with C5Z pads in the rear maybe, but try carbotech XP10 or XP8 up front. They won't break the bank and should help your pad fading issues, and they wear very very well.
Here's a new XP10 on the right, an C5Z pad in the middle (1 day) and a used XP10 on the left with 5 events.
Also--anybody had trouble w/the stock Z06 pads overheating the fluid but not so much fading???
