C5Z Wheel/Brake Clearance
Old 05-23-2009, 10:00 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
Default C5Z Wheel/Brake Clearance
Posted this (more related to weight) a few weeks back as I'm always fiddling with stuff.
http://forums.corvetteforum.com/auto...-hoosiers.html
While the weight is part of some of the difference between the Alcoa's and Speedlines, tonight I checked another hunch I have had eyeballing both wheels over the last couple of years. Two of the differences between the Alcoa and Speedline are spoke shape (more rounded on the speedline) and paint color (darker for alcoa).
The rounded spokes for the speedlines always looked fatter to me, and I always wondered about clearance with big brake kits for such so tonight I measured my alcoa's and speedlines on a 14" 6 pot Stoptech kit that is on a C5 currently in my shop.
In this case of this kit, Stoptech says .080" is min clearance for wheel spoke to caliper.
Here's .085" of clearance on the 02-04 Speedline
And .170" of clearance on the 01 Alcoa w/ it's thinner spokes
Both meet the (Stoptech) spec, but just for more useless, random info, the Alcoa is almost .100" more of spoke clearance.
Back to your regularly scheduled programming...
Old 05-24-2009, 10:48 AM
02impactblue
02impactblue's Avatar
Which wheel did you use on the front for clearance measurements? The 17x9.5 or did you put the rear 18x10.5 on the front. Thanks!
Old 05-24-2009, 12:18 PM
drivinhard
drivinhard's Avatar
18x10.5 (only thing that'll clear a 14" kit)
Old 05-26-2009, 12:53 AM
0Robert@SPEEDSOUTH
Former Vendor
Robert@SPEEDSOUTH's Avatar
Hey, pretty cool, I knew the SPEEDLINES fit over the ST60s, and I referred to the gap as a gnats hair, now I know that a gnats hair is precisely .085".
Interesting that the Alcoa has more room though, never realized that.
Thanks for the post.
Old 05-26-2009, 11:33 AM
froggy47
froggy47's Avatar
So the alcoa weigh more because they are forged, speedline less because cast spun, but speedline dimensions are slightly bigger.
Old 05-26-2009, 11:45 AM
gkmccready
gkmccready's Avatar
Originally Posted by drivinhard
Both meet the (Stoptech) spec, (and it's unlikely there is a wider caliper than the 6 pot stoptech?) but just for more useless, random info, the Alcoa is almost .100" more of spoke clearance.
How far from the rotor face/friction surface does the Stoptech stick out? My Wilwood SL6Rs are 2 7/8" from the rotor face... these are the full full width calipers, not the LGM SL6 that uses the 7420 pad but is slightly narrower, and not the Wilwood kit caliper that uses a 7416 pad.
Old 05-26-2009, 12:05 PM
spazegun2213
spazegun2213's Avatar
wow, thanks for the info! I knew the wheels were different, but i never knew by how much!!!
Old 05-26-2009, 02:57 PM
Z06Fix
Z06Fix's Avatar
ummm Stoptechs
Old 05-26-2009, 03:05 PM
AU N EGL
AU N EGL's Avatar
and how many track turds get pilled and stuck in that gnats hair ?
or do stick on wts interfere ?
Old 05-27-2009, 09:42 PM
drivinhard
drivinhard's Avatar
Looks to be about 2.5" (I was measuring through the wheel, and couldn't get a straight on read angle on the tape, so +/- that a smidge)
Old 05-28-2009, 01:24 AM
rustyguns
rustyguns's Avatar
excellent report! thanks!
Old 12-19-2009, 12:30 PM
gkmccready
gkmccready's Avatar
I should have asked this another way... what's the distance from the rotor face to the wheel spokes? And do you know for sure the 2pc rotor you have on is the same offset as stock rotors?
Old 12-19-2009, 01:16 PM
geerookie
geerookie's Avatar
If I remember correctly the Stop Tech 2pc rotors are offset.
I think it's about 1/4" towards the inside.
Old 12-19-2009, 01:49 PM
varkwso
varkwso's Avatar
you have a disease...nice info though
Old 12-19-2009, 03:28 PM
drivinhard
drivinhard's Avatar
So what you really want is the distance from the spokes to the outside face of rotor (ie, a stock or stock offset rotor)?
Old 12-19-2009, 03:32 PM
davidfarmer
davidfarmer's Avatar
and I've stated for 7 years that they also clear ST40's with no problem. I CAN however state that they will NOT clear PFC's new kit. I have to both run 1/8" spacers AND had to clearance the calipers (with permission from PFC)
Old 12-19-2009, 04:26 PM
gkmccready
gkmccready's Avatar
Yeah. Exactly. Trying to double check if my full width Wilwoods will fit. The Wilwood website says 2.35in so I'm looking for about 2.5" of room from the stock rotor face to the wheel spokes.
To C5Z Wheel/Brake Clearance
Old 12-19-2009, 04:48 PM
Z06cool
Z06cool's Avatar
I just want to know when his garage turned into a "shop". As many cars as I've seen come in and out of there (mine included...:o), I guess it may qualify...
You are obsessed with the details Mark but that ain't a bad thing.
Old 12-19-2009, 05:08 PM
0Todd TCE
Former Vendor
Todd TCE's Avatar
The full body SL6 requires 2.35" but I think if you check with Anthony you'll find the G-stop caliper kit uses the narrow outer body model (for Wide Five apps) and is only 2.13" from the friction surface. That might help you a bit with clearance needs.
Old 12-19-2009, 05:14 PM
gkmccready
gkmccready's Avatar
Yeah. Unfortunately I have G-Stop brackets, but the full width SL6R calipers. Do you know if the only difference is that outside lip being machined off?
Quick Reply: C5Z Wheel/Brake Clearance
