Help finding a C5 Racing Rearend Vendor
Any of you guys have a lead for a good remanufacturer of a heavy duty C5 Z 06 rear end? Need this for a NASA track car. A streetable car, but mostly for Time Trials.
Anyone have any experience on the track with 370 gears in a road racing application? Need a little help out of slow corners. I'm running in TTS and the LS 6 needs a little help to over take a C6 LS 3 in the first 100 feet out of a corner. Seems the cars are equal except for doing the pass in a slow corner. I can make the pass happen, but the LS 3 will pull away just enough out of the hole so I cannot to complete the pass.
Thanks,
Darrell Covert
Realty Executives Z 06 # 96
2008 NASA-AZ TTS Champion
Thanks,
Darrell Covert
Received 8,918 Likes
You might contact Danny Kellermeyer. He ued to race in the TCC and I know he used to use a 3:73 gear in his Vettes. This year he is racing in the WHRRI in Michigan. Here is the contact info:
http://djrace.com/contact.html . He is a retired GM employee with extensive Corvette race experience.
Bill
Bill
Thanks Wayne!
Since the posiunit is broken, I thought I would take advantage of this.
L'tl Blu' should be one hell of a TTS car when back on the track.
Bill
Bill
I purchased a 3.73 diff from RPM Transmissions with a C6Z fluid pump that I routed through a Setrab fluid cooler. I figured while it was out I would make provisions for keeping it cooler.
Thanks guys! Good thought on the cooler!
Anyone driven with 3.73 gears as compared the standard 3.42's in race conditions? We get to 147 MPH at end of straight at Firebird Main Raceway. I know were at 5000 RPM at 104 MPH in NASCAR 4 at PIR. That should be 5,400 RPM with 3.73 gears.
was going to try it if i found a 3.73 cheap never did
definitely go with a rear end cooler!
they rebuilt my t5 tranny and my rear end on a WCC car..(retired)
taking my car there this week to have them straighten out a clutch problem sombody else could not fix...
here is their rear end room
http://
takin mine apart
http://
not mine but is ugly
http://
I can highly recommend Unitrax in CA for rearend rebuilds/upgrades. Very fast service and quality work. Website: http://www.gounitrax.com/
Eric
Eric
Eric
Eric
Rusty, remember Pete has a lot more torque and HP than I in TTR. I'm pretty much stuck with 370 RWHP. Want a little surprise for Gary in Turn 9, when I'm back.
Platinum Supporting Vendor
Thanks David,
Those Getrag contacts are still useful. We still do road race rears we just do not advertise it except by word of mouth. We used to build all of the Banner Engineering diffs before they made the switch to Pontiacs a couple of years ago. Here is a couple of shots from in the back, the REM gear is for a T1 car being built and we are playing with a couple of new ideas right now. If anyone is interested please call me and we can go over some options and figure out what you need and get it built for you.
Thank you
Justin A.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Thank you
Justin A.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Rusty~ I want more kick out of second gear in a slow corner, like Turn 9 at PIR, not less. So going from 3.42 to 3.73 is logical. It will require shifting into 5th on the straight and 4th between turns 8 and 9. I October it took me 4 laps to finally make a pass stick on Gary.
Still interested in you racers out there that have gone from 3.42 gear setups to 3.73. Your track experiences would be appreciated. Advantages and disadvantages (i.e. lower speed corners, additional shifts required, and such at different tracks), please.
