Inside the batwing C5 oil pan
Since there has been some discussion of oil pans and starvation lately, I thought I'd post the pics of my pan:
I've seen pics of some C5 pans which have the floor of the wings as a second cast piece bolted on to the main pan, like so:
http://img183.imageshack.us/img183/783/c5oilpanbw5.jpg
My pan isn't like this; its just one piece. Does anyone know what the differences are between these pans? Are they the same internally?
I'm working with a friend of mine (who designed this baffle for F-bodies) to see if we can get a bolt-in trap-door setup for the C5 pan.
Former Vendor
I'm using a ls2/3 pan in my C5. Better design than the batwing even though it looks much simpler on the outside and it bolts right up.
I see them come up on the C6 parts for sale/wanted section from time to time.
What makes you say its a better design? I've showed the pics to a few people, and they seem to believe the C5 pan is better. Specifically they cite the lower capacity of the C6 pan and the lack of a cover to prevent slosh.
CorcetteTrev (04-12-2022)
Former Vendor
The closest version of this we’ve done is take an LS6 C5 and an LS3 C6 through the same High G turn at Barber, over the tunnel and towards pit in, with the same hot shoe driver in each car and watched oil pressure. Both cars were stock wet sump w/o accusump. The C6 is the faster car through this section, yet it’s the C5s oil pressure that was falling off. Both engines were stock GM, no rebuild. I chose the LS2 pan in my own car because the engine was out, I’m using a 3 qt accusump anyway, the test above, it weighs less, extra capacity isn’t an issue for me especially with the oil cooler, and who knows, GM’s claim that the LS2 pan is “better”, might actually mean for performance, not just for their wallet.
I think that the C6 T1 racers are particularily fond of the "LS2" pan........
If I were wetsump still, it would be the later of the batwings.....I had an LS2 pan on my car when it was wetsump for about 2 months before I went back to the batwing.
Somewhere there were pictures of Chris Ingle's "special" oil pan that GM gave him..........guess what....they turned a LS2 pan into a batwing.
Well isn't this just clear as mud!
So you had more oil pressure issues with the LS2 pan?
So were there two batwing designs? One with a bolt-in floor, starting around 2000 or so? What makes you say its better than the one-piece pan? I'm going to purchase one and post up pics of it too...
Robert, any idea what year the C5 that lost pressure was?
So do you guys think there would be any market for a bolt-in trapdoor setup for the batwings? It'd have small little doors that fit into place over the mouse-holes. The seal probably can't be made perfect on a cast pan, but if it mostly kept oil from sloshing into the opposite wing under cornering, I think it could be a huge help to oil starvation.
Former Vendor
[QUOTE=RAFTRACER;1570211789]I had an LS2 pan on my car when it was wetsump for about 2 months before I went back to the batwing.
QUOTE]
What were the signs that told you the LS2 pan was a problem?
QUOTE]
[QUOTE=Robert@SPEEDSOUTH;1570213871]
Oil starvation, bearing material in oil filter, etc.........
I figured "if it aint broke dont fix it " and went back to the batwing.
The batwing still created some limitations in my application, and was having a hard time keeping oil cool enough so I went dry-sump. Added lots of volume with the dry-sump...
Former Vendor
I've got a few oil analysis sheets from the C6. Some preceeded the oil cooler, some after. I think I have one here from a street driven C6Z somewhere too just for kicks. I'll see if I can scan these and post in a little while. Raftracer, do you have any on the batwing or do you think Chris Ingle has something? It would be great to compare them all. Maybe this would help draw some conclusions.
Great thread!
Great thread!
I forgot to add that when my car was wet-sump it always had a 3-quart accusump on it....
I never got to the oil analyzation part.....I could see bearing material in the filter......never completely spun a bearing. I never let it get that far......Taking engines in and out frequently sucks !!!!
Former Vendor
I'm digging for the analysis stuff now.
When my car is back together, I'll log oil pressure during track sessions and post the results. I just need to decide what oil pan to run...
Robert, see the link I posted in the first post: http://forums.corvetteforum.com/auto...post1569196128
How quick is your C6? Is it a T1 car?
Former Vendor
Here's the link.
http://www.speedsouth.com/files/LS3_SPEEDSOUTH.pdf
Oh boy, lets here David Farmer chime in on this link.
