slight play/noise in the rear wheels
Old 05-31-2009, 02:27 PM
longdaddy
longdaddy's Avatar
Default slight play/noise in the rear wheels
car in the air, grab the wheel at 3 and 9 o'clock, move it around - there is a faint "click" and just a tiny amount of play.
at first i thought my bearing is going, but then i noticed that this only happens if i grab the wheel at those positions (trying to move top/bottom - no noise/play) and this is same on both rear wheels.
this makes me think it is something in the suspension.
ideas?
Old 05-31-2009, 02:59 PM
thehammer69
thehammer69's Avatar
ideas?
tie rod end links
Old 05-31-2009, 04:56 PM
longdaddy
longdaddy's Avatar
Originally Posted by thehammer69
tie rod end links
what's the fix?
Old 05-31-2009, 09:55 PM
thehammer69
what's the fix?
Replace the tie rod end links.
Old 06-01-2009, 12:36 AM
longdaddy
longdaddy's Avatar
is there "better than OEM" replacement?
Old 06-01-2009, 09:18 PM
thehammer69
Check out VB&P's heavy duty ends.
Old 06-02-2009, 10:20 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
You can try a set of the Baer Tracker tie-rod ends, they are actually a bump-steer kit and you have to buy them in pairs. But they are a pretty good set-up. I've only seen one wear out and that was after 3 years of tracking, and even then you would just have to buy a new heim joint.
Jegs has them for $165 pair.
Old 06-02-2009, 10:50 PM
longdaddy
longdaddy's Avatar
just an update - confirmed that both end links are bad, replacing with VB&P
I am thinking this would explain why the rear was jumpy crossing pavement seams with loaded suspension for the last few track days
To slight play/noise in the rear wheels
Quick Reply: slight play/noise in the rear wheels
