Swaybars what ones do I need?
Old 06-01-2009, 09:25 PM
Operations
Support Corvetteforum!
Operations's Avatar
Default Swaybars what ones do I need?
I have a C6Z with the stock sways, springs, shocks, etc.
Currently I have 520/500rw
I leaning to LG coilovers, they recommend the GM T1 bars
But should I consider the Pfadt Swaybars as an option?
Old 06-02-2009, 01:44 PM
waddisme
waddisme's Avatar
Old 06-02-2009, 04:32 PM
NemesisC5
NemesisC5's Avatar
Old 06-02-2009, 06:31 PM
Aaron Pfadt
Aaron Pfadt's Avatar
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Your engine is one factor in your choice of suspension, but I would ask what is your intended use of the car. We at Pfadt have a whole line of swaybars that fit a bunch of different situations.
The Pfadt sway bars offer a few advantages over the T1 bars. They are lighter because of their 3 piece construction that uses 7075 Aluminum for the arms. Our Pfatty endlinks are also custom 3/8" pieces that are 1/2 the weight of the T1 style 1/2" endlinks. They are also a turnbuckle style for easier removal of preload.
The Pfadt bars also offer a much larger range of adjustability than the T1 bars because of the adjustment available on both the front and rear bars.
Feel free to write or call if you have any specific questions on our bars.
-Aaron
To Swaybars what ones do I need?
Quick Reply: Swaybars what ones do I need?
