Mocal LSx integrated oil cooler adaptor and thermostat
Old 06-03-2009, 11:52 AM
GrantB
GrantB's Avatar
Default Mocal LSx integrated oil cooler adaptor and thermostat
Second page of this catalog:
http://64.202.180.37/files/thermos$....t1=Get+Pricing
Is anyone using these? I'm sure they probably aren't going to be compatible with an Accusump plumed into that location, but they still look like a useful product.
Old 06-03-2009, 01:57 PM
ibjamin
ibjamin's Avatar
That looks like a great product for someone adding a separate oil cooler. Saves having to install a separate thermostant and all the additional -AN fittings that would require.
George
Old 06-22-2009, 01:43 AM
GrantB
GrantB's Avatar
Note, this adapter will NOT fit on a C5 pan (either the one-piece or two-piece) without grinding some excess (at least for my Wix filters) material off of the oil filter mount. From the pictures I think it will fit on every other LSx pan.
I called Mocal's distributorship (BAT) and told them about the issue. I believe they are going to make a small spacer to get it to clear the oil filter mount.
I haven't verified fitment with my headers (LG longtubes), but will when I get some heads to bolt on to the motor.
Old 06-23-2009, 02:28 PM
bowtiguy
bowtiguy's Avatar
I have an AOT2-3 180 degree " H style" thermostat housing -10an male fittings for sale. If you are installing an aftermarket (bigger) oil cooler, this is perfect.
brand new $75 shipped.
To Mocal LSx integrated oil cooler adaptor and thermostat
Quick Reply: Mocal LSx integrated oil cooler adaptor and thermostat
