What size poly T1 sway bar bushings for C5?
I need some poly bushings for T1 sway bars for my C5 Z06. Does someone know the correct size and where to buy some?
Thanks,
George
Thanks,
George
I bet www.vbandp.com knows. If you have the bars just throw some calipers around them. VBP has made several sets of bushings for me, even funky custom ones to my spec.
VB&P definately knows. I ordered some from them a couple of months ago. When I called, I talked to one of their technicians and they knew right away what I needed. They included grease too so be sure to ask for some if you order (I didn't ask but they sent some anyways).
The sheet that came with my rear bushings said the rears were 27 mm. It fit the bar very well. I can't seem to find the sheet for the fronts. Sorry.
