Pfadt coil overs...Standard preload?
Old 06-08-2009, 11:07 AM
dredpyrt
dredpyrt's Avatar
Default Pfadt coil overs...Standard preload?
Picked up set of Pfadts from a forum member but i have an issue. Theve been taken apart so i need to reinstall the springs and reset the preload. Anybody have the dimensions for the springs at there proper height? Thanks.
Old 06-08-2009, 11:10 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I have a new set sitting at home... here's a pic of them right out of the box. I can measure them for you tonight if you let me know what dimension you need.
Old 06-08-2009, 11:53 AM
mousecatcher
mousecatcher's Avatar
email pfadt, they will send you a setup sheet.
Old 06-08-2009, 01:12 PM
dredpyrt
dredpyrt's Avatar
Default coil overs
I went ahead and contacted Pfadt directly. Thanks for the responces.
Old 06-08-2009, 01:31 PM
LS3FORME
LS3FORME's Avatar
Could you follow up on this I am upgrading my coilovers to the the delrin top mounts and I do not think they have a preload on them now. That is when they are not under load, the coil is under mininmal compression. The top nut which holds the unit together does get torqued to 14lbs that is the only spec I know of.
Old 06-09-2009, 03:41 AM
dredpyrt
dredpyrt's Avatar
Default coil overs
The # im looking for would be the installed spring height. This would be the either the length of the spring or the distance between the upper and lower spring perches with the locking rings in there "as delivered" position from Pfadt.
Old 06-09-2009, 10:01 AM
igo380
igo380's Avatar
what did they say?
Old 06-09-2009, 11:05 AM
jordan@pfadtracing
jordan@pfadtracing's Avatar
St. Jude Donor '08-'09
Autocross & Roadrace Forum Sponsor
Hi dredpyrt,
I sent a response to your email this morning. Check it out and please feel free to call or email us with further questions. Thank you for choosing Pfadt products and have a great day.
Kind regards,
Old 06-09-2009, 01:59 PM
dredpyrt
dredpyrt's Avatar
Default Coil overs
Got this is from Jordan at Pfadt this morning...The best way to set pre-load is to install the coil overs on the car. Once
this is done loosen the lock ring below the spring until you can move the
spring up and down on the shock. Once this has been accomplished bring the
lock ring below the spring up until the spring doesn't move up and down.
Give it one full turn and lock it down. Thanks!
To Pfadt coil overs...Standard preload?
Quick Reply: Pfadt coil overs...Standard preload?
