Not Just Cooling the Brakes
Former Vendor
Just thought I would point out a unique design feature of our cooling ducts not mentioned in any of our previous posts. Our ducts not only send cooling air to the center of the rotor, they also feature an opening that directs air to the spindle. This helps to cool a very vital part of your car at the track, the wheel bearing.
I happened to be talking with a local racer at the track this past weekend. He informed me of a discussion he had with a GM engineer on this very issue. He mentioned the engineer said all brake cooling kits for the Corvette do more harm than good because they starve the wheel bearing and spindle of cool air. The racer was not aware of our kit, and I doubt the GM engineer was either.
Take a look at the picture below to get a better idea of this particular design feature.
You can see that half of the incoming air goes to the center of the rotor and the other half is directed at the spindle and backside of the spindle/wheel bearing.
Once I informed him about this unique feature of our kit he was instantly sold.
Upgrade to our brake cooling kit and help extend the service life of more than just your brakes.
Do you have an easily-installed (no hub removal, OEM parts modifications or other 'fun' required, etc.) version for the C6 Z06 stock brakes? I'm thinking mainly for us HPDE guys - not necessarily for full W2W racing...
Is it a different kit then the C6 Z51 model?
St. Jude Donor '09
San
