*** F/S: C5R Block ***
Old 06-17-2009, 02:09 PM
0Jon @ LGMotorsports
Former Vendor
Jon @ LGMotorsports's Avatar
Default *** F/S: C5R Block ***
C5R Block
RACE APPLICATIONS ONLY
$5000
Call for more details: 972-429-1963
Old 06-17-2009, 03:00 PM
billla
Support Corvetteforum!
billla's Avatar
St. Jude Donor '14
Old 11-04-2009, 04:24 PM
Former Vendor
Makes a great winter project for next season!
Old 11-04-2009, 04:47 PM
mgarfias
mgarfias's Avatar
I wish. Maybe my dog will start poopin' out gold nuggets.
Old 11-04-2009, 04:51 PM
Todd Z
Todd Z's Avatar
I have three dogs so maybe I can buy everything else that it needs.
Old 11-04-2009, 05:25 PM
Mjolitor 68
Mjolitor 68's Avatar
whats the cid on that ?
Old 11-05-2009, 03:36 PM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Depends on the stroke, most shops will finish the block to 4.125", that way with a 4.000" stroke you will have a 427, but you could put a longer stroke in if you choose for more cubes. Max stroke I believe is 4.300"
Here is the info on the C5R.
DESCRIPTION: C5R BLOCK
This is the same block that was used in the LeMans 24 hour endurance racing C5R Corvettes, and is intended for maximum effort competition engines. This block has the same production external dimensions and bosses, but the primary difference between this block and the Gen 3 production blocks is a siamesed water jacket, which allows engine builders to build engines with larger bore sizes. The delivered, pre hone, bore size is 4.117", and the maximum finished bore size recommended with this block is 4.160". Cylinder deck height is 9.240". This block uses a dry, pressed-in liner similar to other GM racing aluminum small blocks. Steel billet bearing caps are fitted to the block. This block features wet sump style oiling and is made from high strength A356 aluminum that utilizes a modified T7 heat treat. Production Gen 3 style cylinder heads may be used on this block; however, for maximum performance, P/N 12480090 Gen 3 racing cylinder heads should be used.
Old 11-07-2009, 08:13 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Old 11-09-2009, 11:16 AM
Former Vendor
If anyone is thinking about this block, make me an offer.
972-429-1963
Old 11-11-2009, 10:39 AM
Former Vendor
Old 11-11-2009, 10:51 AM
spazegun2213
spazegun2213's Avatar
972-429-1963
Can I start the bidding at $5.32 (thats all the cash i have on me) and my firs born (you might be waiting a little while for that one).
good luck on the sale
Old 11-11-2009, 02:21 PM
66IISS
66IISS's Avatar
I'll raise the bidding to $100 and my first two kids. I'd offer up 3 kids, but I have absolutely no use for the block (right now at least) so you can only have my first 2, whenever they pop out of future-wife.
To *** F/S: C5R Block ***
Quick Reply: *** F/S: C5R Block ***
