Pfadt Sport Shock Optional Upper Mounts Now Available!!!
St. Jude Donor '08-'09
Autocross & Roadrace Forum Sponsor
Pfadt Spherical Delrin Pin Top Shock Mounts Now Available!!!
NEW RELEASE!
With almost a year's worth of development time invested in these mounts, you'll see the advantages immediately! The new Pfadt mounting system uses aluminum and delrin to create a split spherical bearing, unlike any other solution available. All Corvette dampers on the market use either a polyurethane or clevis mount. While both styles are functional, they leave a lot to be desired in terms of durability, weight savings, packaging, and range of movement. Our new mount is the result of taking the time to engineer a better solution for the Corvette from a blank sheet of paper.
One of the coolest features of our new mount is that it removes several inches of wasted space in comparison to a clevis style mount. This allows maximum ride height flexibility and shock travel in the tight packaging space of a Corvette. Our mount does not consume valuable shock length and travel like a clevis style mount.
Weight
Our mount is 43% lighter than an aluminum clevis style mount. Our mount is ultra light weight because it does not need heavy steel bolts or a spherical bearing. We take advantage of the upper shock perch as the bearing half for our large Delrin ball. The entire mount is a Delrin bearing which allows free articulation and has extremely low friction.
Noise
The hard anodized aluminum and Delrin combination allows quiet operation and no noise. Our new mount retains a Delrin barrier between the shock and frame to reduce noise transmission from the road unlike a steel clevis which will transfer road noise into the car.
This upper mounting system is available for a variety of Pin Top Shock applications including Bilstein and Koni Shocks. Here is some fitment information that you can use to determine if these will work with your Pin Top Shocks:
Upper Pin (Stud) Length Minimum: 2.25"
Upper Pin (Stud) Diameter: .450" or smaller
The set of four is available for $250.
Please feel free to call or email us if you have any questions. We appreciate everyone's support on the Corvette Forum and have a great day!
Kind regards,
Weight
Noise
Kind regards,
Please feel free to call or email us with any questions.
Hi Eric!
These are the optional upper mounts we've been working on for some time. I believe you're referring to the updated poly mounts that will be standard equipment on the Sport Shocks. The largest difference between the current standard mount and the new mount is going to be the Sleeve we'll use in the center to control crush. I'll send you some as soon as we get them!
You could get these mounts however and have a better set-up! Give me a call if you're interested, we can work something out!
Is there any upgrade program for those of us who bought the first generation of Pfadt shocks, and are happy with them, but still would be looking for an extra bit of improvement?
Might be something to consider, customer loyalty/rewards/etc.
In the image below do I have the components labeled correctly? I see where the frame goes between the two delrin parts. In order for the shock to rotate in the direction shown (in red), the material on the upper half would have to be compliant wouldn't it? Like rubber or urethane, etc.?
How much does that compliance resist rotation of the shock? Does it provide a benefit over something that rotates freely, like a spherical shape on both halves?
I am looking to upgrade my shocks and want to understand the differences between all the pin top mounts out there. It can be quite confusing. TIA.
Pin Top Spherical Shock Mounts
These mounts will work on just about any Pin Top shock. Please feel free to call or email us with any questions.
Kind regards,
Thanks for the section view, that really helped. Are the pictures of the same parts that are shown in the solid model? They look different.
One other question now that I see the cross section: what happens if the frame flange thickness is different than the space that the delrin halves allow for? It the flange is thicker it would be easy enough to put a washer or shim in place, but if it's thicker there will be a gap that would reduce the included angle of rotation, right?
I'm curious to know how much more space is used between the top of the shock and mounting flange compared to using bushings? I ask this because any space used there reduces the amount of shaft travel you have before hitting the rubber bumps.
The space savings comes when you compare the wasted space that a clevis style mount creates. Below is a picture showing the difference.
I hope this answers your questions. Please let us know if you have further questions.
Kind regards,
Please let me know if you have any further questions!!
Kind regards,
Our mounts will work with Bilstein Sports as well as the HD. I'm working on a post now that shows the mounts installed on various shocks including the Bilstein Sports.
No problem!!! Please let us know if you have any further questions!
These mounts will work with Penske Pin Tops!
