C6Z06 wheel studs
Old 06-22-2009, 12:21 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default C6Z06 wheel studs
haven't done this lately, never done it on a C6Z06. Can you swap to longer studs without removing the hubs??? Last time I tried on another car, it seems like I could get the OEM studs out in the front, but couldn't get the longer ones back in. An of course the rear is worse.
Anybody done this lately???? I need spacers, and can't afford to lose any more thread.
Old 06-22-2009, 12:25 PM
wallyman424
wallyman424's Avatar
never tried it with the hubs in the car, but from what I recall the fronts should be fine... but with the rears the dust shield gets in the way.
pulling the hubs only takes a couple minutes, and makes it much easier.
oh, and ARP studs are a PITA to press in.
Old 06-22-2009, 02:50 PM
Lan.Jet
Lan.Jet's Avatar
I just did this two weeks ago and I ended up having to remove the Hubs.
Old 06-22-2009, 03:06 PM
davidfarmer
it's a "couple of minutes" I don't have right now. Guess I'll just have to let the calipers and wheels continue to "self clearance" themselves at VIR!
bowtiguy
bowtiguy's Avatar
I just completed a swap to the SKF hubs and ended up swapping in the ARP studs prior to hub install. IMHO, it would be nearly impossible on the rears, but OK on the fronts.
I backed the lower ball joint nut up to the half shaft housing ( to protect thw ball joint stud threads), placed a small chisel between the two and gave it a slight wack to seperate the spindle from the ball joint to give me access to the hub bolts.
I also took the opportunity to install 2" sections of silicone hose around the ball joint dust sheilds at the same time.
Old 06-22-2009, 03:08 PM
wallyman424
mine did that for a while.
FYI, the caliper gets clearanced not the wheel, so no big deal.
Old 06-22-2009, 03:17 PM
davidfarmer
Not these Performance Friction calipers.....the monoblocks have already cut a thin groove through the backs of all of my spokes. Wasn't bad over the winter, but the heat is really causing them to expand I guess.
Old 06-22-2009, 03:22 PM
wallyman424
ah shoot, i forgot you had those bling brakes. sweet.
Old 06-22-2009, 03:25 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Nope, you have to pull it all apart, especially on the rear. If you want the new SKF's we have them with the racing studs already installed.
Old 06-22-2009, 04:27 PM
davidfarmer
Problem is the OEM's are all still in good condition, plus I still have a full set of GM Racing bearings left from my racing days.
I certainly not one who minds a good days work, but I also am not one who likes to tear things apart unnecessarily!
Thanks for confirming my memory!
To C6Z06 wheel studs
Quick Reply: C6Z06 wheel studs
