Accusump questions (C4 LT4)
After an oil pressure scare that turned out to be a bad pressure sending unit at Summit Point I have pretty much decided to do whatever I can to protect my engine from an oil standpoint. It is an LT-4 block 383 with a Canton oil cooler already installed via the sandwich adapter that goes between the block and the filter. If I add an accusump to this setup, where should I run it from? Should I "T" into the return line from the cooler or go from somewhere else?? Thanks as always!
-Bryan
-Bryan
I forgot to type my other few questions!
As far as the valves go, does anybody have any recomendations? The car is 99% track use and with the pump that is in it now usually stays above 50psi hot. I have glanced at the gauge under braking and it drops pretty drastically.
Also, how big would you guys say I need to go? I know obviously that the bigger the better, but is a 3qt really needed? I am on a pretty tight budget, but want to do what I need to do to protect the motor.
If you're looking for an Accusump for cheap, I have one that's never been used for sale. I think it's the 3 quart, but I'll have to check (pretty sure). Currently has a manual valve installed.
Look for a hole with a plug in it on the side of the block just above the oil filter. If your block has this factory hole you should be able to remove the plug allowing you to connect directly into the oil galley to your oil accumulator.
Received 1,753 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I am putting an accusump in my L98. Is there a possibility that hole is in my block too, or just the LTX blocks?
Not all blocks may have a hole with a plug in it. You will need to inspect your block. If you don't find one at this location you might check with a machine shop that is familiar with your type of block and see if they are aware of other openings to the oil galley.
If there is no hole, you can configure it like I did on my LS6, and attach it from a
"T" on the oil cooler return line, so that it feeds into the adapter block return. You will need a check valve on the oil cooler line just before the T so that a pressure drop does not allow the oil to flow back thru the cooler.
I have a sandwich adapter like this one, that has a thermostat in it. I dont think the return line is blocked, but if I tap into it, will the accusump have trouble getting pressure at startup if the inlet line is blocked? Or will the whole system get pressurized even through the return line?
Here's an accusump pdf that contains a diagram of what I'm trying to describe: http://www.accusump.com/accusump.pdf/instructions.pdf, it contains installation instructions for both styles of connections (adapter block to oil cooler, and direct engine oil passage)
I have the Lingenfelter adapter block that fits on the oil temp port of the LS6, but the concept is similar in that you have oil out to the cooler, and a return line coming back in such that the cooled oil then gets fed into the motor. The check valve only prevents the pressurized oil from the accusump from going the wrong way when there is a drop in oil pressure, as you want that to go into the motor, and not back thru the oil cooler in the wrong direction.
I understand that, but my adapter restricts flow OUT until a certain temp. Im worried that when I turn the car on and the electronic valve starts the preoiling, that all 3 quarts will be dumped into the engine and have to stay there until the oil is up to temp to flow out the adapter, through the cooler and back to the accumulator. OR, at startup will the oil flow back to the accumulator through the INLET of the adapter (backwards through the return line) like Im hoping.
