FS: 4 Calipers: C5 & HD VBP-Vette Brake Prod
Old 07-03-2009, 11:18 AM
Racer Buzz
Racer Buzz's Avatar
Default FS: 4 Calipers: C5 & HD VBP-Vette Brake Prod
For Sale
Set of four (4) HD brake calipers
1 pr VBP - Vette Brake Products C5 fronts &
1 pr CORVETTE C5 fronts (for use on rear)
BRAKE CALIPERS & PADS
Need a great set of four brake calipers for HPDE / on-track use in your C5 Corvette? Well here they are and for a fraction of the cost of a new set.
1 pair front VBP / Vette Brake Products heat “coated” calipers with their super heavy duty, lightweight, heat resistant “titanium” and ventilated pistons complete with a set of Hawk pads (used).
AND
1 pair stock front Z06 brake calipers, complete assembly with a set of Hawk brake pads (used).
For use on the rear with a pr of front rotors, same bkts.
All the above complete with four (4) mounting brackets for 14” front C5 rotors
$500.00 OBO
BUZZ FYHRIE
Ft Lauderdale, Florida 33324.
E-Mail: rcrbuzz@bellsouth.net
Cell #954-612-3606
Old 07-03-2009, 01:24 PM
longdaddy
longdaddy's Avatar
good luck with the sale.
what's involved in getting front calipers to work on the rear? do you need to change front/rear bias? do front calipers work with stock rear rotors or did you need to get a rotor without the parking brake drum?
Old 07-04-2009, 09:15 AM
Racer Buzz
Racer Buzz's Avatar
Same Corvette caliper mounting brackets but must use the front style rotors and remove the complete parking brake assy. If for racing you can control the F-R bias with different brake pad compounds.
BUZZ
Old 07-05-2009, 10:31 AM
Racer Buzz
Racer Buzz's Avatar
ttt
Old 07-15-2009, 09:51 PM
Racer Buzz
Racer Buzz's Avatar
ttt
Old 07-18-2009, 10:14 AM
Racer Buzz
Racer Buzz's Avatar
ttt
To FS: 4 Calipers: C5 & HD VBP-Vette Brake Prod
Quick Reply: FS: 4 Calipers: C5 & HD VBP-Vette Brake Prod
