Pfadt Pin Top Delrin Spherical Mounts for MOST Pin Top Shocks!
St. Jude Donor '08-'09
Autocross & Roadrace Forum Sponsor
NEW RELEASE! THE FIRST AND BEST DELRIN SPHERICAL MOUNTING SYSTEM FOR PIN TOP SHOCKS ON THE VETTE!!!
With almost a year's worth of development time invested in these mounts, you'll see the advantages immediately! The new Pfadt mounting system uses aluminum and delrin to create a split spherical bearing, unlike any other solution available. All Corvette dampers on the market use either a polyurethane or clevis mount. While both styles are functional, this Pfadt mounting system offers the ultimate in durability, weight savings, packaging, and range of movement. Our new mount is the result of taking the time to engineer a better solution for the Corvette from a blank sheet of paper.
One of the coolest features of our new mount is that it removes several inches of wasted space in comparison to a clevis style mount. The photo below uses a coil over comparison to highlight the space savings of our spherical mounts. Our mounts allow maximum ride height flexibility and shock travel in the tight packaging space of a Corvette. Our mount does not consume valuable shock length and travel like a clevis style mount.
Weight
Our mount is 43% lighter than an aluminum clevis style mount. Our mount is ultra light weight because it does not need heavy steel bolts or a steel spherical bearing. The entire bearing surface is Delrin on hard anodized aluminum which allows free articulation and has extremely low friction.
Noise
The hard anodized aluminum and Delrin combination allows quiet operation and no noise. Our new mount retains a Delrin barrier between the shock and frame to reduce noise transmission from the road unlike a steel clevis which will transfer road noise into the car.
This upper mounting system is available for a variety of Pin Top Shock applications including Bilstein, Koni, QA1, Penske as well as O.E.M. Shocks. Here is some fitment information that you can use to determine if these will work with your Pin Top Shocks:
Upper Pin (Stud) Length Minimum: 2.25"
Upper Pin (Stud) Diameter: .450" or smaller
The set of four is available for $250.
Please feel free to call or email us if you have any questions. We appreciate everyone's support on the Corvette Forum and have a great day!
Kind regards,
Weight
Noise
Kind regards,
