The Speedlab Corvette.
New film
Incar movie "dogma style" from our test drive at Barkaby Airfield.
Hard to see the log on the film but we shift from first gear to second at aprox 120km/h and reach 200km/h before we have to brake.
http://www.speedlab.se/wordpress/?p=553
Speedlab driver
/Johan
Speedlab driver
/Johan
Cool, the engine sounds real nice. Did you guys fix the splitter grounding issue? Weren't you going to increase the spring rates?
Yes, we are but this video is shoot the same day as the other one. The idea with a softer rate is to get a larger ride height reading when working with the down force adjustments. The team has had a few weeks of so the work has been standing by for a while. As soon as I get some baseline aero setting, especially for the rear diffuser, we should go on with testing a few new wing profiles. Then I should calculate for new spring rate and rebuild the shocks accordingly. I will probably use a 3:e vertical spring. Goran
Yes, we are but this film was taken on the day of the second. The idea of a softer suspension is to get a larger difference in åkhöjd when working with aerodynamic adjustments. The team has had a couple of weeks holiday, so the work has stood still for a while. As soon as I get some basic Aero settings, particularly for the rear diffuser, should we proceed to test some new wings. Then I will calculate the new spring rigid units and rebuilding shock absorbers. I will probably use a 3rd vertical spring.
Goran
Video reminds me of the old muscle car stories where somebody tapes a $100 bill to the dash and "if you can reach it, it's yours!" and then starts accelerating...
Now we have been out on the track test driving the car. I must say that we are very pleased so far. We increased the front wheel rate to prevent the splitter from hitting the ground. We need to reduce the expansion of the rear diffussor with 2 "to raise the downforce effect. Greater expansion reductions resulted in less downforce. The rear wing was mounted to dramatically increase rear downforce. At 110 mph, we had about 600p over the rear axle.
Here is the starting diffusser level.
Here's how it looks after adjustment.
The steering was good feeling when all the downforce came with, and the manual concept car is working well.
We were wondering how the almost zero consolidated front end geometry would work, 1 SAI dgr, 2 dgr caster and almost no scrub. But together with the manual steering so the drivers thought that the feeling in the steering wheel became even better and cleaner.
We are now starting to get a better picture of how the spring system must be designed and we will probably use a third vertical system that has about 1/2" clearance before it stops kompression from downforce. In this way we can go right soft suspension (more front roll stiffness) at low speed and get good acc grip out of the curves.
Goran
Goran
Feels good with support, becouse this has been 24 hours a day work
for a long time.
We are going to mount a larger front master brake cylinder for more rear braking, and do a few braking tests at the local straight, mount the final design splitter and then go back to the track 9 of Oktober.
I hope there will be more good news to report.
Goran
Now we have tested the car a bit more and everything seems to work well so far. There will be no more tests this year for winter makes itself felt in Sweden now, but we have a good picture of what needs to be addressed in the winter. Aerodynamic look good, both for distribution and power. As you can see on the previous images we have placed the wing very fare back, actually behind the car which seems to help diffusser good. In any case, so we can have a greater expansion in diffussern with the wing in this possition. We have currently about 1700p at 120 mph, distributed fairly equal weight distribution is 56% rear. It might seem a lot but the measurement is made over the suspension system and may contain errors of measurement. I'm talking mostly about aero and it is because that is what I was most uncertain if I'll manage to get to the good. But the car has of course many other sides worth mentioning, but it takes more out of racing driving for an opinion. Now we hope for a successful racing 2010th
Goran
Goran
During winter time, we have made some little things with the car, among other things,
I have designed a new carbone fibre airfoil that we now have to try.
The wing is mounted using "swan neck" that has lightening cut outs filled with balsawood
in order to lessen turbulence.
A new rear diffusser is also made since the old adjustable show what sort of expansion
to run.
We also did need a third vertical spring to cope with the downforce, and this is what it
comes to look like.
The same with the front diffusser, a new one is made.
I am very excited to see how all this works and the test run is imminent.
Goran
to run.
comes to look like.
Goran
#33
Our first race ended in disappointment, left wheel did not hold up with the load in a right curve and the result is visible in the picture. Fortunately, the car landed on track after an air journey which could have stopped really bad.
Goran
Goran
#35
The wheel on the picture was to get the car on the trailer.
Goran
#37
Goran
#39
Quite right, the audience got a good view of the entire underside of the car when it broke the side plates of the wing against the ground. So the Speedlab team is very happy after all, that they still got a car that with minor repair will be ready for race within a month or so.
Goran
Goran
#40
Received 1,753 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
This car looks awesome! It would be a shame to destroy it, Im glad things worked out in your favor.
