The Speedlab Corvette.
#41
Expressed in a slightly sarcastic way, you should not have to reinvent the wheel, but in my case it seems literally to be what is needed. Today, there are a variety of wheels on the market, it's just a lot of different looks with the strength and weight and other key ingredients are not emphasized in advertising. If all the pieces fall into place so I will have the resources to develop my own wheels, which also (in the middle of all the bad luck) is actually very interesting. I have negotiated with a manufacturer of motorcycle wheels and brakes here in Sweden that manufactured brakes for Nsacar cars in U.S., and they are willing to set up and produce four sets wheels (16) according to my drawings. I will keep the Corvette Forum informed of the plans progress.
Goran
Goran
#43
Goran
Goran
#44
Here is the first scetches for my new wheel for the Corvette. The design
is not based on look, soley on strength and weight. But as fare as the look is
concerned, if you look at a drop of water falling down so it is shaped
by the laws of nature, and with all your mind in shape, most of us will
think it is neat. It is my view that if I can draw a design with the laws of
physics as it can in any event not be totally ugly.
Goran
Goran
#45
A picture of my new wheels, they are not exactly the same drawing, when the model proved tricky to produce. But so far, it has been up to the task.
Just a picture of the Corvette an my Pantera.
http://www.hemipanter.se/Mantorp%20012.jpg
If everything turns out okay we will do the first race for 2011 next weekend.
Goran
Goran
#47
This weekend we were at Falkenberg Racing Track in an attempt to implement an entire race. The car works flawlessly, so we had high hopes. It started well with a few test laps, but then the powers of Nature took over with a terrible rain. We had forgotten the wipers at home so we were able to just run the last race. We were still at it with a third place, thanks to good downforce, which allowed us to better braking at high speed than the competitor on the cold wet ground.
Our holding tent did not load during the night's downpour, but collapsed over our car. Luckily the car was not injured.
The staff had a good job of pumping out the new lake that the competition area blessed with.
Goran
Goran
#48
I forgot this one, one more version of wheel center. With the manufacturing method available, this wheel is not so bad. Very strong according to the simulations, without spending months of testing and manufacturing difficulties. But really, I would be able to produce the original model that I think would have at least the same strength but a much more an appearance of its own. Though the look is not the fundamental in this case.
Goran
Goran
#50
We have had problems with some understeer so I rebuilt the diffrential. Instead of the load-sensitive plate pack I made a new packages using a roller bearing which makes a completely open differential. It's not quite what you are accustomed to seeing on a race car but this car has an incredibly low center of gravity so I thought it was worth a try. It turned out that the driver was very satisfied. Now we can use a more balanced coilover-spring setting.
This weekend, 12-8-2012, test-driven the car with the new diff and the result was two victories in two races on Anderson Stop Raceway. I am really pleased with that.
It really takes some time to get things right for a small team....
#51
Here is a film from the inside of our car at Anderstorp. There was a problem during startup because the driver was not familiar with the open diff, so we was passed by a few cars. In addition, he was out on the grass due to cold tires. These cars are later passed, and in the end there is a car left to pass but it is one lap behind.
http://www.youtube.com/watch?v=FjLl-...ature=youtu.be
Goran
Goran
#53
Sweet car.
Thanks for keeping us updated.
#54
We have manufactured a new front to our Corvette now, it is in one piece and considerably lighter. This picture shows the "plug".
This picture shows the mold, in all consists of four limbs.
The front mold.
The final front.
The final front. There are cutouts for diveplates if you wonder what it is for.
The front mold.
The final front.
#55
Is the plug an old hood design just modified? Are the modifications done in fiberglass, or are you using clay/foam anywhere? Just curious.
#56
Goran
Goran
#57
Goran
#58
Hey, it's been a while since last time. I have rebuilt our Corvette and endowed it with turbochargers and a lower weight to 2200pound. Even the aerodynamics has got itself an update. The pictures show a bit of the work over the last year. Nira engine managemant and completely sequentially with 8 coils. Active brakes and aero is also on the "to do work" list.
#59
Wow thanks for coming back and showing us that. THe car looks better than ever, I like what you did with the side strakes etc.
No intercooler ?
How much boost are you running ?
Meth/water injection ?
I assume you are running some pretty high octane fuel.
Is the new turbo system race/track proven ?
Any concerns with turbo heat affecting the front tire ?
Is that dual wastegates on the passenger turbo ? At first I thought the second unit was a blowoff valve that was plumbed into the exhaust !
No intercooler ?
