leakdown and compression test numbers?
Old 07-13-2009, 02:07 AM
trackboss
trackboss's Avatar
Default leakdown and compression test numbers?
Anyone know what are good/bad numbers for c5 motors? Mine is a '99 LS1 with roughly 30k miles. I tested my motor and the leak down came in the 11%-16% range. Compression came in at 180-235 range (bank 2 compression test, passenger side, showed much better numbers than bank 1). Keep in mind that I did it on a cold motor (don't currently have radiator).
thanks,
-V
Old 07-13-2009, 11:32 AM
bowmanized
bowmanized's Avatar
You basically want to see right around 8%. Up to 12% is ok for a higher mileage car. After that it's not good. 16% is a little poor but you also said the car wasn't warm.
If you squirt a little oil down in there you'll know if it's the ring. Sometimes it can be something in the cylinder heads.
Hope this helps,
Mike
Old 07-13-2009, 01:27 PM
sperkins
sperkins's Avatar
Old 07-13-2009, 01:49 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Originally Posted by trackboss
180-235 range
-v
180/235=76%
Old 07-13-2009, 07:08 PM
trackboss
trackboss's Avatar
It's actually 24% variance. For some reason I thought 180-200 was considered good. It's been some time so I really am not sure. Considering this was all done cold I am ok with my leakdown numbers. The compression test kind of concerns me.
To leakdown and compression test numbers?
Quick Reply: leakdown and compression test numbers?
