Are narrower wheels/tires better for a wet track?
I have been simplifying my wheel/tire packages such that I am square (315x18) on all four corners for my track wheels and spares. I want to get a set of wheels/tires for the street that are also a good wet track tire. I have the opportunity to buy 4 C6 18x9.5 wheels and was considering putting something like the Goodyear D3s in 275 on them. The thinking being that they will move water and the narrower profile will less prone to hydroplaning; certainly not immune.
My primary goal is good wet track performance with tires that can stand up to street use; I realize this is a compromise.
Suggestions welcome.
Vetteless
St. Jude Donor '09
I would guess you'd find a 275 square setup to be on the loose side in the wet - which is very exciting but not necessarily the goal! I ran 275F/315R Hoosier wets on my racecar and was always impressed with how they performed in the rain. The narrower fronts helped avoid hydroplaning, though I found that in standing water 115-120mph is about all I could muster before the car began making moves of its own without my input and I ran out of cajones.
The biggest thing that always surprised me was how well I could hook the rear of the car up exiting slower corners in the rain - which I attributed to the 315's back there working hard. My tires were Hoosier rain tires, not GS-D3's, but my experiences made me believe the sizing was very good. Hope that helps!
one important thing in a really wet surface is tread pattern. A tire that channels water will do much better than a standard street tire, and that will obviously do much better than a slick.
I think width isn't as important in general IF you have a true rain tire, BUT width can really hurt you if you are running a slick/R tire in the rain.
I used to run Wide Ovals when I had 17"s up front. They did well for me in the straights even crossing running water. They were reasonable in the turns, but needed their limit respected. When they wanted to let loose, they just went - they were also rocks, treadwear of 330 I think.
Received 1,730 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have a C4 with 17x10.5 wheels all around and 285/40/17 D3s as my street tires. My plan too is to use them at rain events. I have not had to use them at the track yet, but messing around town in the rain the car feels very stable and hard to break loose. They are great for wet traction!! In a downpour on the highway there is no hydroplaning in 1-2" of standing water at about 70mph. I have used them in a couple autocrosses too and they grip excellent in the dry as well.
Received 8,919 Likes
Keith,
I found the WOs work especially well in deep water like we see at the Glen when it is pouring. Once the track drops down to merely wet the DOT Rs actually work a little better. The Goodyear DS3s may be as good of a rain tire as the WOs but I have never tried them. If you run the 275 in front that will increase the amount of pressure per square inch on the ground which should also help but it may be better to run a 295 Vs a 315 in the rear with the 275 in front.
Bill
Bill
BTW I say run narrow in the wet (when I say wet I mean you're trying to move water). Just regular non standing water "wet", R comps work very well (as noted above). And I have been planning on doing the same as you, running 275/17's on my spare 9.5's for street (very little these days) to/from the track and track wets.
Pretty soon if I sold the stuff I have to KEEP my car off a trailer (streets/hitch/tire trailer/toolbox/yearly tag dues), I could buy a trailer
Bill
