**Offical LG GT2 Corvette Rebuild Thread**
Old 07-17-2009, 01:57 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default **Offical LG GT2 Corvette Rebuild Thread**
Hi guys,
Everyone remembers the scary and horrible fire at Long Beach with Boris behind the wheel of our GT2 Corvette. I am happy to announce that the car is going back together now and will make it's first appearance at the Corvette's of Carlisle show then onto Watkins for it's first shake down runs before Atlanta.
Fire!!
Blasted and Cleaned Frame
Frame being Primed
Frame being painted
Frame complete in red
Front Suspension mounted
Rear suspension going together
Center Switch panel stack
Dash rebuilt and ready for install
Pedals, Steering column, and shifter being installed
Louis and myself are going at it pretty quickly now, so I will be updating the thread with new pictures as the car comes together so STAY TUNED!!!
Old 07-17-2009, 02:02 PM
rfn026
rfn026's Avatar
Wow - that is really apart. is this the first time for the car to be totally apart since it arrived?
Richard Newton
Old 07-17-2009, 02:12 PM
Kubs
Kubs's Avatar
Received 1,748 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Wow! Looks great! Good luck with the rest.
Old 07-17-2009, 02:44 PM
RedLS1GTO
RedLS1GTO's Avatar
This is going to be an awesome thread...
Old 07-17-2009, 02:51 PM
bowmanized
bowmanized's Avatar
Wow, that's so sick Lou. The tank must be the dry sump.
What's the total weight(wet) without driver?
Glad to see you getting it back together.
Go get 'em.
Mike
Old 07-17-2009, 02:58 PM
Former Vendor
Richard Newton
Louis stripped it down at Riley right after Sebring 2008, this is the first time since then that it has been this far apart.
Old 07-17-2009, 03:05 PM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
We stripped it down to basically suspension and wiring after Sebring in '08, then flipped it to correct the floor flatness, but did not have time to completely strip it and paint it like this. We are allowed 5mm deviation from a pure flat bottom
Old 07-17-2009, 03:07 PM
wmckeenster
wmckeenster's Avatar
GREAT thread!
Old 07-17-2009, 03:38 PM
Lancer033
Lancer033's Avatar
Old 07-17-2009, 05:06 PM
HORNDAWG
HORNDAWG's Avatar
Cool, good to see the car coming back together. Now for some sponsorship!
How much longer does the chassis have on its homologation? And can Riley re-homologate/update the car/chassis/design and extend its homologation life (ACO) as long as it is in production?
L.P.
Old 07-17-2009, 05:40 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
We're going to miss you at Lime Rock this weekend!
I like your bushing solution
Old 07-17-2009, 06:46 PM
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Go get 'em.
Mike
Hi,
Yes, that is the dry sump tank. The car has to weigh 1220 kg with no fuel and no driver. that is 2684 lbs. This will be the absolute first time it will be exactly down to min weight. We were close before but this time we should need a little balast.
Lou g
Old 07-17-2009, 06:47 PM
StealthLT4
StealthLT4's Avatar
Aw man! I was really looking forward to seeing the Corvette at Lime Rock this weekend. Good luck with the rebuild!
Old 07-17-2009, 06:52 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
never mind
Old 07-17-2009, 08:03 PM
LG Motorsports
We will keep you all updated as the car goes back together. It will be at Corvettes of Carlisle in 5 weeks. Stop by if you can make it.
The homologation is all ACO is still being worked on. GM originally granted the GT2 Homologation to Riley then they changed their mind when they were forced due to not enough bail out money to run GT2.
So Gm pulled their promise on the FIA homologation but that is supposed to change now that they are pulling out of most racing around the world. So Riley is working on the FIA part as we speak.
LG
Old 07-17-2009, 08:26 PM
JEPopp
JEPopp's Avatar
St. Jude Donor '13-'14-'15-'16-'17
GREAT THREAD & PICS !
Too bad it won't be together in time to run up at Road America. With the power you have, I would think the long straights might play to your strength. (But I may be completely wrong, I'm just a fan of road racing with a Corvette in the garage)
Old 07-17-2009, 11:01 PM
longdaddy
longdaddy's Avatar
what's "brake blower"?
To **Offical LG GT2 Corvette Rebuild Thread**
Old 07-18-2009, 01:09 AM
LG Motorsports
Brake Blowers are in line 3" fans that blow air through the brake ducts for use mainly on Yellow flags and during a pit stop if necessary.
LG
Old 07-18-2009, 07:18 AM
jrmotorsports55
jrmotorsports55's Avatar
Glad to see it's coming together.
Good luck!
Jason
Old 07-18-2009, 08:43 AM
Everett Ogilvie
Everett Ogilvie's Avatar
Glad it is going back together - great build thread!
Quick Reply: **Offical LG GT2 Corvette Rebuild Thread**
