Laguna video
Old 07-21-2009, 10:52 PM
Rob Burgoon
Rob Burgoon's Avatar
Default Laguna video
requires DivX codec.
http://www.trackhq.com/forums/photop...368/ppuser/450
This was at 48 psi hot. Not much of an example for technique, line, smoothness, or any of that, but the car stayed out of the dirt!
In 5 20 minute sessions on track the car suffered:
3 cracked rotors
2 brake failures (4+ pumps to get the brakes to work)
1 or 2 spread brake calipers
3/4 of the front pads gone
possible bad wheel bearing
Old 07-22-2009, 01:28 AM
Sidney004
Sidney004's Avatar
3 cracked rotors
Good Job Laguna Seca is murder on brakes!
Still trying to get the video to play.
Old 07-22-2009, 01:32 AM
Rob Burgoon
Forgot to mention that it was around 75* out and I got the oil up to 308* and coolant to 230*
Old 07-22-2009, 01:50 AM
Sidney004
Sidney004's Avatar
Those are good numbers, you were revving it up! Nice video, those Nitto's are a handful, I wonder what they are like at 55psi
Old 07-22-2009, 04:59 AM
flink
flink's Avatar
That carnage seems excessive. Rob, what sort of brake cooling do you have there?
Save http://www.trackhq.com/forums/photop.../50psi_lap.avi to disk and you'll have an AVI file after 1.5 cups of coffee.
Old 07-22-2009, 08:06 AM
PA Z06
PA Z06's Avatar
pretty cool, what pressures did you start at.
Old 07-22-2009, 08:56 AM
redtopz
redtopz's Avatar
Nice vid. Sounds like you had some serious carnage! I was there on Thursday with Sidney and ran 4 25 minute sessions with no real problems except my ABS and active handling warning light was on all day.
Bill
Old 07-22-2009, 10:31 AM
Rob Burgoon
33 psi cold. For brakes the car has the base model napa rotors and the mild C6Z06 ducts.
Also, the brakes weren't being used very hard at all, due to the lack of tow hooks and lack of confidence in them.
The car seems to lose a bunch of power when it heats up.
Old 07-22-2009, 12:33 PM
Sidney004
Sidney004's Avatar
15 psi pressure build up is really high. 8-10 psi is what I am used to. It could be the tires were filled with saturated air.
Your brake carnage is because your tires are crap, you might not be braking hard but you are probably braking often and feathering the brakes because you lack confidence in the grip thru the corners.
Laguna Seca is a short track and if you are braking often there is no opportunity to cool them down. The heat builds up in the brakes; pad wear rate increases, calipers spread, rotors crack, fluid boils.
Do yourself a favor and get rid of those pieces of wood, you will go faster thru the corners, brake less and consume less brakes.
Old 07-22-2009, 01:09 PM
Rob Burgoon
Your brake carnage is because your tires are crap, you might not be braking hard but you are probably brakingoften and feathering the brakes because you lack confidence in the grip thru the corners.
No unsolicited advice please.
The tires did fine. I lack confidence in the brakes as well as my muscle memory since I am used to car 1000lbs lighter with a much higher grip to weight ratio.
I also didn't want to find out how the corvette would behave in the dirt, so I kept the mid corner speeds down.
Finally, the car lacks tow hooks, so a trip into the gravel would be unacceptable.
Old 07-22-2009, 01:40 PM
ryan0
ryan0's Avatar
n00b.
Old 07-22-2009, 01:43 PM
Olitho
Olitho's Avatar
Originally Posted by ryan0
n00b.
Rob, you really should be open to more advice at least until you get 70 races in this year. How many are you at now? Only 68 or something, right?
Old 07-22-2009, 01:49 PM
ryan0
ryan0's Avatar
or at least until your street car is is fast at laguna as my japanese econo-box street car is.... er.. was.
Old 07-22-2009, 01:54 PM
Rob Burgoon
The stock seatbelts weren't helping things either.
I know exactly what it would take to make this car work right, and I am simply unwilling to make that commitment.
Old 07-22-2009, 02:17 PM
ryan0
ryan0's Avatar
thats the strangest feeling of all.
Old 07-22-2009, 03:22 PM
RX7 KLR
RX7 KLR's Avatar
A better driver.
Old 07-22-2009, 03:47 PM
Rob Burgoon
Originally Posted by RX7 KLR
A better driver.
I agree with that. The car needs a driver that is willing to take some risk.
In this car, I am not that driver.
To Laguna video
Old 07-22-2009, 03:54 PM
Rob Burgoon
40 or so races so far this year I think it was.
Old 07-22-2009, 06:01 PM
RX7 KLR
RX7 KLR's Avatar
Once you bend it you will have a much easier time justifying the T1 build.
Old 07-23-2009, 12:33 AM
Bimota Guy
Bimota Guy's Avatar
I was there a few weekends ago watching MotoGP. Pole was a high 1:21.
Quick Reply: Laguna video
