Spun into Mud: Now Vibration in RR & Pulsating Brake
Old 07-22-2009, 09:39 AM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
Default Spun into Mud: Now Vibration in RR & Pulsating Brake
Ok, spun out into the psgr side of the car.
Right rear I think I now detect a small vibration once I hit 80, for all i know lost a weight... havent had time to check yet. Will also check wheel balance.
The right rear pfadt coil is a bit slack and is clicking, i need to tighten the preload.. knew before session.
Can It just be a worse preload issue causing it to wobble assuming the rim/balance is ok?
Also I think my ActHand/ABS came on in future laps a bit earlier and more agressively in the later sessions. I was definitely driving the car harder as the day went on... but once or twice I really went Hmmm that wasnt worth helping me yet...
Could that be a hub/bearing/sensor needing replacing?
Is there a chance that I could have even bent a rear shaft leading to a hub to cause this? What are the signs of the shaft? THose suckers are pretty hard to gnarl up arent they? Way more than an easy mud slide right?
The pulsing brake shows ueven rotor contact going on in the firepath of the rotor, you can clearly see a outter vs. inner contact friction difference now.
Argh. All this and 2 cracked front rotors in 4 sessions.
Old 07-22-2009, 11:09 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
probably just packed some mud in someplace
been there done that!
check that 1st.
did you replace the cracked rotors?
missing chunks would explain that too.
Old 07-22-2009, 11:11 AM
AU N EGL
AU N EGL's Avatar
check that 1st.
take it apart, inspect and clean it out
Old 07-22-2009, 12:53 PM
dcvee
dcvee's Avatar
, also check for a flat-spot. They'll make a car shake at higher speeds as well...even a small one.
Don
Old 07-22-2009, 12:56 PM
meldog21
meldog21's Avatar
Watch the movie "My cousin Vinny." Then take off the wheel and inspect everything else mentioned above.
Dog
Old 07-22-2009, 01:08 PM
Zenak
Zenak's Avatar
power washed the mud out last night already, still pulsating today when i drove it to work.
Old 07-22-2009, 02:13 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Hey Keith,
If you stayed on the track you wouldn't have this problem.
I would jack up the back side of the car and check to see that all of the your suspension hardware is tight.
Also check to see wheel bearings are tight by grabbing the outside of tire and see if you detect any rocking or loseness.
Also check tires, you might try swaping the left and rear tire to see if that fixes the problem.
At what spped do you feel pulsations ??
Old 07-22-2009, 03:07 PM
Glennm27
Glennm27's Avatar
Received 1,403 Likes on 610 Posts
2017 C7 of the Year Finalist
St. Jude Contributor
Originally Posted by meldog21
Watch the movie "My cousin Vinny." Dog
To Spun into Mud: Now Vibration in RR & Pulsating Brake
Quick Reply: Spun into Mud: Now Vibration in RR & Pulsating Brake
