08-09 C6 F55 converting to zr1 F55 specs
Old 07-25-2009, 07:10 PM
ro9beam2002
ro9beam2002's Avatar
Default 08-09 C6 F55 converting to zr1 F55 specs
Was doing some searching but not sure.
From what i gather, if C6 08-09 has the F55 shock system, it is the same as the ZR1 shocks and hardware? With the exception of launch control tuning. "Can you not re-tune, c6 f55 software to include this feature?"
Also to make this work you would have to change out the front springs to stock Z51 springs.
The rear would have to be a "modified" z06 spring. What are the specs for this modified rear z06 spring?
The sway-bars are thicker, same as the z06 or zr1 specific?
Then i guess you could add the same size wheels and tires, with the correct offsetts and tire sizes.
Then the brake rotors and pistons
Has this been done to a 08-09 C6 F55 vette?
Quick Reply: 08-09 C6 F55 converting to zr1 F55 specs
