c5 radiator support
Old 07-26-2009, 07:14 PM
mgarfias
mgarfias's Avatar
Default c5 radiator support
Just pulled the nose off my car and realized I smacked something on the road a few years ago and bet the support pretty badly.
Anyone have one laying around that they'd part with?
Old 07-26-2009, 08:28 PM
TedDBere
TedDBere's Avatar
gmpartsdirect: About $240...it's called a skid bar. Be sure to order the rivnuts...you'll need 7 of the 6mm and 1 of the 8mm ones. Pain in the butt putting them in without the tool. You can use an 8mm and 6 mm x 1.25 threaded bolt and a nut/washer and hold the head of the bolt while you collapse the rivnut by tightening the nut.
Oh...and you'll have to paint the skid bar too.
However, if you can find a used one that isn't bent that would certainly be an easier solution.
Good luck.
Old 07-27-2009, 07:25 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I thought the rivnuts were mounted in the frame....shouldn't need replacing unless they are stripped.
Old 07-27-2009, 09:37 AM
TedDBere
TedDBere's Avatar
There are an additional 4 8mm x 1.25 rivnuts in the frame too. The ones on the skid bar are used to attach the air pump, the horn, the middle air dam and air dam supports.
Old 07-27-2009, 10:02 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Just buy used, I picked one up for $150 and didn't have to install any of the nuts, once the bumper cover is off it's a really easy install.
Old 07-27-2009, 10:40 AM
99BlackZ51
99BlackZ51's Avatar
I have a brand new one painted, with the rivnuts installed for $275 shipped.
Scott
Old 08-27-2009, 10:10 PM
dcsalarm
2nd Gear
dcsalarm's Avatar
Scott
do you still have the skid plate. If so I'd like to purchase it
Old 08-28-2009, 11:20 AM
99BlackZ51
99BlackZ51's Avatar
Yes I do, send me your email address and I will send you pics.
Thanks, Scott
Old 08-28-2009, 07:55 PM
dcsalarm
2nd Gear
dcsalarm's Avatar
sent you my email with a pm. Post again if you didn't get it and I'll resend
To c5 radiator support
Quick Reply: c5 radiator support
