Sparco Evo's in a C4 - Rail adaptor ?
Old 07-27-2009, 10:25 PM
Axelrod
Axelrod's Avatar
Default Sparco Evo's in a C4 - Rail adaptor ?
Can you separate the factory seat rail in a C4 and reuse it with the Sparcos (similar to a C5 setup) or ?
Thanks!
Old 07-28-2009, 09:19 PM
RAFTRACER
RAFTRACER's Avatar
Yes...............
Old 07-29-2009, 11:58 AM
RedLS1GTO
RedLS1GTO's Avatar
Yes, you can take the factory rails off and use them for a bottom mount seat. Although, I'm 6'0 and with the power track I was WAY too high up to fit with my helmet with a Kirkey seat, even as low as the track could go.
Old 08-01-2009, 09:51 AM
The Dingo
The Dingo's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Originally Posted by RAFTRACER
Yes...............
But aren't Sparco EVO's side mount only? AFAIK the factory rail will only work with a bottom mount seat.
http://www.sparcousa.com/resourceFiles/26.pdf
I used custom mounts to mount Sparco Corsa's in my C4.
To Sparco Evo's in a C4 - Rail adaptor ?
Quick Reply: Sparco Evo's in a C4 - Rail adaptor ?
