Importance Of Proper Engine Cooling = MORE HP & TQ
Last weekend I was running a NASA event at VIR. The ambient temps were 95 Deg + and the car was running coolant temps in the 220-230 Deg range and oil temps in the 265 range at the end of a session. The car seemed to be down on power a bit due to the heat. I decided to take advantage of the on site Dyno facility at Viper Engine and Drivetrain lab on Saturday afternoon. The dyno graph of the 4 pulls is below.
Cooling and the temp of the engine coolant played a major factor in the power production. The car has complete factory stock intake, engine, exhaust and programming. I am running a DRM exterior oil cooler. The first three runs were performed with coolant temps between 225 and 230 Deg. This was to simulate the actual track conditions of the day. Best HP was 351.1 and TQ was 330.1. Cooling off the temps to 205 on the 4th pull produced a substantial increase in HP and TQ. Max rear wheel HP 366.6 and max TQ of 350.2. Increases of 16.5HP and 20.1 TQ !!!
I know what my next mod will be a Ron Davis, Dewitts or other dual row aluminum radiator. Who has experience with the aftermarket radiator units and whose do you recommend ?
I recently installed a Ron Davis in my C5Z and have run 3 events since. Coolant temps have been in the 200-210 range and oil temps in the 225-230 range. Seeing this, my instructor at CMP said "gotta love those Ron Davis radiators." Good luck.
Bob
Bob
before I set my car up properly with coolers from DRM I could see it going flat after 10 minutes of running hard. I have said this many times before here.
I use the LG Supercool Radiator with the oil cooler. I ran at an event last Thursday in 102 degree heat. Track temps were above 120 degrees. The highest coolant temp I saw all day was 207 and oil temp was 247.
I run distilled water and water wetter and have no air conditioning condensor in front of the radiator so your results may vary.
But, it's a damn good radiator.
Former Vendor
We have seen some of the same results on our dyno. It's just the way it is. The ECU does most of it, but even with all that tuned out, your results are going to be about the same.
We use Ron Davis radiators all the time, fit, finish and cooling have been great!!!
Randy
Randy
The only way it will help with power is if you tune for it (i.e., don't let the ECU pull the timing or add the extra fuel). The octane will help prevent detonation as it is.
Most of us in T1 use the Ron Davis and it is very good. I think any good aftermarket version with a high capacity will work very well. There are several you can get though with different features...such as an integrated oil cooler...integrated tranny cooler, etc, etc. Don't forget about the tranny and diff!!!
Running down here in the south (100 degs, 100% humidity), I just don't think you can get enough cooling.
Former Vendor
Randy
We suggest using a tick of race gas in just about everything at the track. With the heat, long pulls over and over, the rpm and pounding the crap out it. It just is a little safety at the end of the day. A few gallons of race gas per tank, is one of the cheapest things about a track day. Pump gas is crap and sometimes you get a bad tank of it.
Randy
Randy
Do you think that cooling off the oil/coolant temps also allowed the intake temps to drop enough to let the computer throw some more timing back in? The stock tune starts pulling timing at around 85* if I remember right, and the reduced underhood temps may have brought the intake air temp down enough to contribute to those gains.
Don't get me wrong, I think lower operating temps will help make power, just wondering with a stock tune if the air temp was not a factor as well.
Thanks for the info
Fej
Thanks for the info
Fej
Thanks for the info
Fej
Thanks for the info
Fej
Another thing that can rob power is if you trip CAT Over Temp. You can then command an afr as rich as 11.7 to 1.
